Question about Freezers
Kenmore upright freezer
Thanks. i will check the overload. i noticed that the timer gears dont seem to rotate after having it plugged in for 12 hours. would this also be tied to the overload?
  • 828 Answers
Timer is before the power to the compressor and overload protector and is unrelated with the exception that the power passes through the timer to the thermostat and then to the compressor. Power at the compressor indicates that the timer is supplying the power. The gears in the timer turn one cycle every 8 to 12 hours depending on the model of the timer.
Posted on Sep 14, 2008
I have a Kenmore upright freezer model# 253.9260210. We noticed that our food was starting to thaw. I opened up the coil area and noticed a small piece of ice on the coils. I melted the ice and turned...
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
Dec 08, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Jun 04, 2010 | Woods Upright Freezer V1613RW3
Temp alarm reoccuring every 12 hours
Your freezer is going into a defrost cyc unknow why is the door gasket gapped or the defrst timer is not advancing properly
Aug 28, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
HI I HAVE AN OLD 13 CU. FT KENMORE UPRIGHT FREEZER. AFTER I DEFROSTED IT YESTERDAY AND AFTER IT HAD BEEN PLUGGED IN FOR ABOUT 6 HRS I NOTICED THAT THE SIDES OF THE FREEZER FELT VERY HOT . IS THIS NORMAL ?...
It had to run longer than normal to cool down the freezer again. The heat from the compressor running is what you feel.
I would not worry about it unless it is still hot after 24 hours. Then there is another problem.
May 03, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
No it is not the timer. You may have an open overload protector at the compressor. Check across the overload for a reading with an ohm meter. If it reads zero it is good, if not replace it.
Sep 13, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
78 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
