Question about Sony Cyber-Shot DSC-S60 Digital Camera
Will not turn on
When I hit the power button, it makes the audible sound of turning on, but immediately turns itself right back off. I have tried new batteries...that does not seem to be the problem. The lens is also stuck in the open position.
As far as I know, my camera was not dropped or damaged to cause this. I was using it at a picnic and went to turn it on again to take more pictures and that is when it started.
  • kmeuse508 Nov 29, 2008
    same exact thing yet I can still see the pixs I had taken previously
I had this same problem with my camera a few years back and took it into a camera store to get it fixed. It turned out that it was just the batteries I was using. You cant use regular AA batteries for this camera because they give too much power. If you just go to a walmart or target or anywhere like that, you can get AA camera batteries and that SHOULD solve the problem. let me know if that works.
Posted on Jan 26, 2009
    Problem Solver:
  • 4 Answers
You may need to hit the camera reset button
Posted on Jun 19, 2009
Last night about 3 am I turned off my tv. when I usewd my remote to turn it back on it would not ( t v) come on and no picture or sound . I turned it around to see the back of it but it has no reset
Your TV have faults on Horizontal deflections, the oscillator and the Flyback might be the problems. If you are not familiar with TV circuits?... call tecnician to check your set.
Oct 03, 2014 | Televison & Video
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
After tv has been turned on for a few minutes , screen and sound will go off . after i immediately hit the on / off button to turn it off then immediately turn it back on , it will stay on for a few...
Sounds like bad power supply, but polaroid more commonly has problems with there main controller board (the one with all the inputs) Power supply's are fairy cheap and easy to replace. Check www.RNS-Systems.com or E-bay for a replacement. For more detailed info create a new post with your make, Model, and mfr date as polaroid changes part numbers.
Oct 16, 2009 | Polaroid Televison & Video
Mp3 player has no sound and wont shut off
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. OR Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
Oct 07, 2009 | Nextar MA750-20 MP3 Player
Receiver makes clicking sound when I push power, but does not turn on.
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Jul 04, 2008 | Audio Players & Recorders
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Sony Cyber-Shot DSC-S60 Digital Camera Logo
382 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
