Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag Wide by Side Freezer not working
Our 5 year old Wide By Side has been making noises for the last 2 or 3 days, seemed to be working fine. Yesterday the freezer wasn't as cold as it should be. We adjusted the control, turned it colder. Today everything in the freezer is thawed, and the refrigerator side is warm also. It sound like the fan is working then it buzzes and shuts off. What should we do?
  • 4 more comments
  • BU1wife Sep 14, 2008
    The fan is still working, any other ideas?
    Checked all of those, everything seems to be running. Nothing is blocked. I opened the freezer and it is trying to cool. As soon as I shut it I heard a buzzing noise.
    The refrgerator side is warm also.
    ok dumb question, how do I get to the evaporator coils. The only thing I can remove on the back is a cover to the fan. The black tank is very hot.
    Haven't heard anything back, could you please help with my question.
    Thank You
  • BU1wife Sep 15, 2008
    Thanks I'll see what I can find out.
    Master:
  • 726 Answers
The actual thermostat seems like its buggured can tell to get warm or cold and it will defrost the freezer
Posted on Sep 14, 2008
  • chris07551 Sep 14, 2008
    yes i would say the thermostat has gone if the side gets warm
    i was thinking the cooling element but it hads to be cold for that ,so the thermostat aint working so the cooling element and cooling i bet u 100 percent its the thermostat
  • chris07551 Sep 15, 2008
    the coils are on the back of the fridge freezer and are screwed in you will see them
    President:
  • 1,952 Answers
Try to defrost it manually. the defrost heater cycle is malfunctioning.
you send me your model number ill look it up for you is the frost at the bottom or top of the freezer as i beleive this model has an automatic damper control and ill tell you how to get a rep svc man after were done ok
  • mohammed marika thambi
    mohammed marika thambi Sep 14, 2008
    Sounds like a defrost problem or dirty coils under the machine. Check to see if
    there is any frost buildup in the back wall of the freezer. If so, it is not
    defrosting as it should.
    • possible causes:
    1. bad defrost timer/control board
    2. bad defrost heater (in freezer)
    3. bad thermo switch in freezer
    If you don’t know what these are then unplug the machine and let the ice
    melt in the freezer overnight with the door open. Then try it the next day, if
    is cooling fine then you need to have a service person replace one of the above
    items.
  • 958 Answers
Open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
  • 1 more comment
  • francis rivero Sep 14, 2008
    have you seen the evaporator coil?..is it covered with frost? or ice blocked the whole evaporator?
    if not, then please check the condenser fan near the compressor at the back, that could be the fan that stopped working.
    keep me posted
    tnx again,
    drcool
    the buzzing sound could be the evaporator fan. this fan runs as you close the door. can you test your evaporator fan by pushing the freezer door switch and watch the fan if it would run and maybe you can also find where the buzzing sound is coming from.
    and alos can you describe the evaporator coils, how far can you see frost on the tubes?..is it just at the top? up to the middle portion or all of the coils has a thin film of frost?
    do all the test while the refrigerator is plugged in.
    tnx again
    drcool
  • francis rivero Sep 15, 2008
    sorry for the delay,
    you have to remove all the trays inside the freezer section and unscrew the back panel inside the freezer section.
    then slide the back plate where you would see the evaporator.
    that black tank is the compressor. maybe it is safe to unplug the unit first for about 4 hours to coll down the compressor.
    tnx again
    drcool
I have a side by side maytag fridge model number MSD2655HES it is about 6 years old. It seems to be cooling fine but makes an intermittent buzzing noise followed by a click what could this be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Maytag MSD2655HES Side by Side...
Freezer noise and defrosting
You need to contact a repair shop ASAP.
May 01, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
Fridge making a humming noise every 3 min
check and see if compressor is running it is in the rear behind the cardboard cover if it is super hot then you need to get a tech out to look at it and it may still be under warranty
Jan 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My freezer works fine, however my fridge is not cold. It seems as there is no air flow in the fridge. I have checked behind the crispers to ensure nothing is blocked. I have a Maytag msd2734ge, wide by...
check in the freezer side and look at the back wall and see if there is any build up of frost, your coil may be block, so no air flowing through the coil, your unit may not defrosting, you need to check the defrost heater,the defrost timer or the defrost thermostat one of these part can be defective
Dec 11, 2008 | Maytag MSD2734GE Side by Side Refrigerator
Maytag Wide by Side (5 years old) Freezing Refrigerator & Freezer
There is 2 things you can replaced to rectify this problem .
1 is the defrost timer and the next is the thermostat.
On the thermostat is a metal rod that is connected to a vent so when you adjust it it open or closes the vent .Just make sure that is not loose because if it's loose even though you turn thermostat down the vent would be wide open allowing freezing air to get into refrigerator.
Jun 03, 2017 | Maytag MZD2752G Side by Side Refrigerator
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Maytag wide by side
you're lucky, these fridge's are garbage!
Jul 08, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
121 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
