Question about Hotpoint HSS25GFP Side by Side Refrigerator
Leaking refrigerator Almost every morning water leaks out of the bottom of freezer door (left side at the corner) on to the floor.What can I do to fix the problem, before I have to call someone in? Thanks! John Kelly
  • 958 Answers
That is where the drain pan is located. it seems that the drain pan is overflowing which should not happen.
kindly check the condenser fan located at the back near the compressor. it should be the one blowing warm air at the drain pan to heat the water to evaporate.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
I have a jenn air side by side and water seems to be leaking near the front left corner area at random times and when it does leak it is a slow drip.... thoughts?
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Oct 31, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer door is leaking water at the bottom of the door
This sounds like the defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle.
If you can see ice on the bottom of the freezer floor, then this is likely your problem unless your ice maker is leaking from the top of the freezer.
Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Water leaking from door: top left door of my french door fridge (with freezer on bottom)--water leaking from the very bottom right corner of that left side door
your drain is clogged. if ice isbuilt up in the freezeer floor. when the freezer defrosts and the drain is clogged it has no where else to go other than ouot the front. pull everything out of the freezer and check twards the rear at the bottom. remove as much ice as possibile let set unplugged and door open for 3 hours. then take a cup of boiling water and pour it back there. if it dont drain repeat that process with the water-have a towel ready because if the water stays back there long enough it will get cold. you need to keep the water HOT. ice could be built up in the drain. hope this helps
Oct 28, 2009 | Refrigerators
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Feb 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
115 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
