Question about Nintendo Wii Console
Eject i cant eject my cd from the wii.you cant put a cd in either.i need help
  • jesdanhaag Sep 19, 2008
    i can't eject a game cube game and can't put any other disk in, wii or game cube.
  • 32 Answers
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 04, 2009
  • 43 Answers
Get a technician to look at it or take the wii apart yourself if you're brave enough to see if anything is jammed. nintendo may fix it if its a fault in a mechanism but otherwise you'll need to see a seperate technician
Posted on Sep 19, 2008
I put a CD in my Wii. i cant get the music CD back. This is the dumbest thing ever. I put my Music CD into it and it wont play! HELP!
what i would recommend is to unplug the unit and hold the power/eject button for 15 seconds. Plug the unit back in and hold the eject for 10 seconds while the unit is on. Let me know if this assists your problem or if you need further assistance and i will be glad to assist you. Thanks and have a great time with your Nintendo Wii
Aug 27, 2010 | Nintendo Wii Console
My son put a Nintendo wii disc into my ps3 and i cant get it to eject please help !
look for small hole near cd tray put toothpick or something small in hole and push
Dec 19, 2009 | Sony Playstation 3 (PS3) Console
Cant get my disk out of the wii
Sounds like the mechanism inside of the drive is bent out of shape or needs to be reseated properly so it can accept and eject disks out. This is going to require opening up the Nintendo Wii and getting the drive out of there.
Here is what the inside of the wii drive looks like:
https://www.vgcrepairs.biz/zen_store/images/Wii_dd_btm.jpg
It could be that the plasic piece that holds the discs in place just needs to be moved back into the center position.
Heres a guide to taking apart the Wii:
http://forums.lovingwii.com/nintendo-wii-hardware/425-guide-disassemble-nintendo-wii-video-pictures.html
Hope this info helps.
Jul 04, 2009 | Nintendo Wii Console
I can't my Disc to eject from my Wii Console. Does anyone have a solution to this problem, other than taking it in for service?
Try all of these steps:
1. Turn the Wii off and on again after about 20 seconds. Press the eject button again. If no help:
2. Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. If no help: 3. Hold down the eject button for 5 to 10 seconds. Still not: 4. Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. if no help: 5. See if power light was coming on and do the AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for 5-10 seconds Finally: Call Nintendo 1-800-255-3700 and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Good Luck
Mar 03, 2009 | Nintendo Wii Console
Console ejects my cd
Jan 13, 2009 | Nintendo Wii Console
Wii disc
ok there is a safe way which requires opening top case try not to turn wii to much while taken off the top case this will keep your cd's from getting scratched
the cd's have lodged ontop the back plate
the other way
turn side ways you should be able to shake machine youll here the cd's slide onto each other lay flat and both cd's should slide out on tray
this will definatley scratch your cd's but it does work and its a form of the shuffle
May 28, 2008 | Nintendo Wii Console
Wii help!
we got it to work eventually by using a pin (ie a dressmakers pin). We realised the eject button wasn't clicking when pushed down, so was physically stuck, so used pin to pop the left hand side of the eject button out/up. Works a treat now.
Feb 20, 2008 | Nintendo Wii Console
Nintendo wii system gamecube game is stuck inside ,everything else still works
it's the ejectijon button cause i have the same problem but with a wii disc
Feb 09, 2008 | Nintendo Wii Console
Cd stuck
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Sep 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
100 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
