Question about Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW
Freezer not cooling
Have frost free freezer but does not cool. The top two racks get cold but the bottom two do not. Compressor runs. Do I need to replace freezer or can it be fixed?
    President:
  • 1,462 Answers
Remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
Posted on Sep 14, 2008
  • anthony matthews Aug 06, 2013
    This is a haier commercial frost free system I am talking about.
    I will get back to this problem on Tuesday thank you.
Why
if the compressor is running but not cooling most likely you have a freon leak in the sealed system,you can tell by looking at the evaporator coil,the coil should have an even frost pattern covering it,if frost is just on top you have a freon leak,also if you have a defrost problem and the coil is covered with ice this also will keep it from getting cold,look at the coil to see.good luck
Aug 26, 2014 | Kenmore 4.6 Cu. Ft. Compact Refrigerator...
My frost free FZA30 has a build up of ice on the bottom shelf. Is there a cure?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Hotpoint Freezers
My Frigidaire Heavy Duty Upright Freezer is not freezing. The compressor is running. Only the first section of the coil in the top rack is getiing cold. Manufacture date is 2002 and it's been used for...
Yes, it does sound like you have a slight leak and a recharge is needed...
But...
Be very careful as to who you get to do that as many are not experienced enough to work on fridge units...they are very touchy and need to be serviced by someone familiar with the small refrigeration units and also someone that is licensed to use refrigerants...
heatman101
Feb 02, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
My frost free freezer is frosting up. what can I do
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Kenmore Freezers
My freezer is not getting cold, but there is frost on the top rack.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 25, 2010 | Kenmore Freezers
Kenmore 106.42102301 (top refridg, bottom large freezer) water draining from cold air vent gradually building up on racks and bottom.
heatman101
Sep 17, 2010 | Kenmore Freezers
The freezer is not cooling
If this is not a frost free freezer to determine which component has failed please do the following.
Unplug the freezer wait 5 minutes and plug back in. Listen closely for any sounds by the compressor. If you hear a click or hum followed by a click the problem is the compressor and would cost about $400.00 to repair.
If you do not hear any sounds the problem is most likely the cold control or sometimes called the thermostat2_bing.gif.
If this is a frost free unit the problem could be with the defrost cycle or the fan motor.
Apr 26, 2010 | Kenmore Freezers
My amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have...
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Nov 04, 2009 | Amana 15.0 cu. ft. / 425 liter Upright...
My top 2 racks frost up and the bottom 2 barely feel cold
If the condenser coil (in the back) is clean ,it is probably that the unit is low on refrigerant(freon) which means there's a leak , and before recharge it is has to be repair(the leak).
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore upright freezer.
Will need a little more information to assist you with answers. Will need the model number if available for you Kenmore and will usually be on inside Freezer/refrigerator door and near bottom. Will look like model #363.1234567 for example.
Now if it's not cooling at all, is the compressor running beneath the fridge? Is the condenser fan running that is below the freezer and near the compressor? Is the evaporator fan blowing air in the freezer section? Do you hear clicking noises in the compressor area and can you feel the compressor to see if you feel warm or hot to touch around its side and top? Can you tell me of any other things that you noticed before the refrigerator stopped working? Is the temp control digital or manual settings? Has the settings been changed since you turned the refrigerator off and then back on? Thanks, Sea Breeze
Oct 28, 2007 | Freezers
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Logo
353 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
