Question about Ovens
Beko DCC4521w cooker grill element
Hi There
Grill element is not working what is the procedure to replace it
Many thanks
Steve
  • 99 Answers
It is done from the rear and inside cavity.Can be supplied approx £24.00+p&p,Check old element for continuity.
Posted on Oct 11, 2008
Hi, I have a belling electric oven and separate grill. The two hobs on the left don't work, the grill doesn't work and the front elements in the oven itself has stopped. Is it fixable? Thanks.
Go to the circuit breaker location on your house and locate the one for the oven. Try flipping it on and off a couple of times. If the breaker only supplies 120 volts the heating elements won't work but the light and clock will. If resetting the circuit breaker fixes the problem, it will happen again, so replace the breaker to do a permanent fix.
Dec 14, 2015 | Belling Ovens
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2013 | Ovens
Grill element - 3 connectors, which one is earth?
The earth connector will be the one that is on the left of the element in the picture and the tag that is connected to the metal case of the element which LOOKS like the upper one. The central core is the heating element and it doesn't matter which is positive of negative as it is a simple circuit.
your first link is broken.
http://stoveconnection.com.au/store/images/0122004499-01.jpg
Jul 09, 2017 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Ovens Logo
234 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
