Question about Hifonics Brutus BX 1205D Car Audio Amplifier
Bad Hum I have a bad hum in my subs. i changed my subs out and its still there I have a Hifonics Brutus BX1205d What do i need to check??
  • mojocanes Sep 14, 2008
    It does pulsate with and with out the ingnition on
    Problem Solver:
  • 8 Answers
Make sure you have a good ground from the amplifier to a metal surface in the car. Make sure this surface isn't paint covered and use a solid wire if possible (not stranded) to complete the ground.
Does the Hum pulsate?
Does the Hum get louder or softer when the ignition is turned?
Make sure your speker cables are not coiled or wraped up and or near any transformers, batteries, or other wires that have current running through them.
The most important thing is grounding.
Posted on Sep 14, 2008
Hifonics 1500D started to hum through subs after beating on them. Unhooked rca's and not the sound. Any ideas?
Check power supply diods. power supply capacitors and power supply and output transistors.
Remember, distortion is the biggest killer of subs and amps. Everything made by anybody has its limit.
Apr 16, 2010 | Hifonics Brutus BX 1505D Car Audio...
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
My gale 3080 sub has a bad mains hum
Check that it properly grounded so that you don't have "ground loop hum" and that you have no power cords crossing other connections.
Oct 12, 2009 | Gale 3080W Subwoofer
!!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
Sep 02, 2009 | Hifonics Brutus BX 1205D Car Audio...
Hifonics brutus bxi 2008 amp. no power output
MAKE SURE SUBWOOFER OUTPUT ON YOUR RADIO IS ON IF NOT THAT COULD BE BAD INPUTS ON YOUR AMP
Aug 07, 2009 | Hifonics BXI2008D Car Amp
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
Illuminating the sub
i would assume hooking it to the remote and ground of the amp
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Problem!
you have a foulty amp i wtake it bk and change it
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Hifonics Brutus BX 1205D Car Audio Amplifier Logo
113 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
