Keep getting an error code F1 - Washing Machines
  • Dan Sharpe
    Dan Sharpe May 11, 2010
    On what washing machine? If it's an HE2 it would be an eeprom error on the ccu board, which can also occur if plugged into an improperly grounded outlet.
I have a kenmore elite model 110.2703 and i keep getting
error code F1. help
Posted on Dec 06, 2008
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
Keep getting F1 error code on my cabrio whirpool top load washer. Can you help?
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control board and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Sep 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F1 error code on my whirlpool elite washer at beginning of cycle and at beginning of rinse cycle, why?
F1 error code usually refers to a control board or touch pad failure in a whirlpool washer.
Hope this helps if you have any further questions message me back Thanks Rick
Jul 17, 2011 | Washing Machines
I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
Dec 07, 2009 | Cars & Trucks
Error Code
A error code F1-09 deals with the finisher of the copier. Have the bins gotten stuck or got something in it's way when moving up & down. I would turn the copier off and unplug the finisher from the copier, 1 screw holds connector in. Then I would turn it back ON and see if the code is gone, if so reconnect the finisher and you should be good to go...
Jun 11, 2009 | Sharp AR 201 Copier
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Nov 18, 2008 | Fisher Dishwashers
Getting error code F1 and F3 on my matag oven... the darn thing keeps beeping too
f1 error code is a defective touch pad or control board.. the f3 error is a shorted temp sensor.. you might be better off just getting a new oven. check on price of parts first.
May 14, 2008 | Maytag Kitchen Ranges
Washing Machines Logo
438 people viewed this question
Top Washing Machines Experts
