I have an issue with the picture on some of my channels on my sky hd box I did a full reset which solved the problem for about 20 minutes and now its back. its not all channels just some i.e. ITV, Sky News etc
No volume on my tv
Posted on Sep 14, 2008
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
No signal on sky
There may be a problem with your tv setup.Perform the following steps below:
1.Press the standby button on your Sky remote and switch off your Sky box at the mains. Check that the power light on the front of your Sky box is off before proceeding.2.Check your cable connections 3.Switch your Sky box back on at the mains. Wait 4 minutes before pressing the sky button .You may see a message before viewing resumes, on Channel 998.Tthat's it
Dec 09, 2013 | Computers & Internet
Cant get full screen picture on my Sky tv channel
The set or a box if used may be able to correct this--some programs are only in letterbox or 4x3 format.
Question: Does the set play a full screen version of a DVD?
Jun 07, 2012 | Televison & Video
There is no sound coming through on HD channels, it has been working fine with no problems but woke up yesterday morning and it no longer works. we can watch tv with sound through the normal scart but...
What TV model is it?
You should begin by unpluging the TV from the mains and have the TV unpluged for at least 3 minutes, if that does not work then you need to factory reset the TV, but note that you will loose all of your previous settings on the TV.
I hope this solve your problem.
Jan 02, 2011 | Televison & Video
My philips hd tv does not have a picture . only
Do the channel controls work? If not, then try going into the TV's menu and find the factory default reset function. If that solves the issue, you may have to do that every time you turn your TV on.
Just as with almost every other issue, I suggest you get in touch with the manufacturer for proper assistance.
Jun 03, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Apr 22, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Picture Switching through Sky HD
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 04, 2017 | Hitachi 42PD9700 42 in. Plasma Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
