By network54
Hello, i just recently got this Zenith for free. It appears to be a 27" screen (from visual inspection, and looking at the model number). I have done some breif looking on this forum and am not really sure where to start. The screen will work fine for a few minutes, and then will start to shrink down, top and bottom will shrink into a smaller picture or into one line in the middle of the screen. What should i start with, and where should i start?
Best Solution
posted on May 30, 2006
You have bad capicators in the vertical section or possibly bad solder connections on the vertical I.C.. Even if you find bad solder connection on the I.C. this is usually caused by the bad capicators. If you are not a TV technican or do not have a low wattage solder iron, solder, solder wick, and a capatiance meter, I suggest you take it to a shop. By the time you spend time to purchase these items you could pay someone to repair it.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony BRAVIA KDL-40S2000 40 in. HDTV
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Sony BRAVIA KDL-40S2000 40 in. HDTV LCD...
Sony Bravia KDL 40X2000 HDMI...
We have our PS3 and DVD player... Answer This...
TV Problems!
TV Problems!
Hello, I have a Sony BRAVIA KDL... Answer This...
problem with klv-32s310a
When I turn on the tv, the... Answer This...
Sony Bravia KDL32W4000-...
Whenever the TV is on - DVD,... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
