No display with ASUS M2NE Motherboard
No display in either VGA or DVI mode on ASUS M2NE motherboard, I am using 9600GT graphic card with Benq FP71E+. ASUS mobo is under warranty.
Many many thanks for solving my earlier problem Azkeyz. Now I am having display in DVI mode with FP71E+ on gigabyte motherboard. But, no display with M2NE motherboard.
    New Friend:
  • 68 Answers
For getting display, you must have four components,
1. CPU (alongwith cooling fan)
2. Motherboard
3. RAM & of course
4. Power Supply (SMPS)
They must be connected properly and after attaching power supply unit you must ensure that a 24pin connector as well as a separate 4pin connector are connected to the Motherboard.
If the display doesn't come, the trouble may be with any of the four devices connected together. for advanced trouble shooting, please elaborate exactly when and how the problem has been generated. If the problem arised at the stage of initial assembly of the components, please check the components individually, if possible, replacing with another prouct of the same type.
If the problem arised on a running machine, please remove the RAMs from the slot, wipe the connectors of the RAM with a softe clean cloth and re-attach. If possible, you may wish to clean the RAM-slots on the board with a vacuum cleaner. In most cases, cleaning the RAMs do the needful.
Please try & reply.
Posted on Sep 16, 2008
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I have new intel dh55tc . I get display through nvidia graphics card . can I get display through vga.
Hi.
You can get a display through > DVI, VGA, HDMI which are on-board. You can also use the nVidia card which may be better.
Regards.
Jun 15, 2011 | Intel DH55TC Motherboard
I installed a video card based on my motherboard.The problem is that DVI does not work, only VGA. It is possible to run DVI? My motherboard is a Asus P5KPL-AM SE.
hello cristitincu
my name is ausi.
on video cards that have both vga and dvi you should be able to use both. if one (the dvi in your case) does not work and has no display the the card is defective. if the card is still under warranty you need to take it back.
please note in some cases i have seen faulty dvi ports working when you turn the computer on. they show you the system boot screen but loose it all after that.
good luck
hope you find this helpful.
Jan 06, 2011 | ASUS P5KPL-AM SE Motherboard
Is nvidia 9600gt graphic card compatible with asus p5rd2vm motherboard
Yes.
1) The Asus P5RD2-VM motherboard has a PCI Express x16 slot.
The Nvidia 9600GT uses a PCI Express x16 slot.
2) The PCI Express version used on the Nvidia 9600GT is PCI Express 2.0
The PCI Express technology used on the Asus P5RD2-VM motherboard is PCI Express 1.1
The motherboard chipset used on the Asus P5RD2-VM shows us this.
The motherboard chipset is an ATI RD480. (Before AMD bought ATI out)
The ATI RD480 chipset came out September 27, 2005.
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges
Scroll down until you come to > RD480 in the left column, then read across.
The PCI Express technology started under another name, then was changed to PCI Express.
The first version was PCI Express 1.0
Then PCI Express 1.1
In 2007 (January 15) the PCI Express 2.0 technology was brought out.
The PCI Express 2.0 technology is Backward Compatible with the PCI Express 1.1 technology.
(With PCI Express 1.0 also, but it depends on the graphics card being used)
In otherwords, a graphics card that has been based upon the PCI Express 2.0 technology, will work on a motherboard based on the PCI Express 1.1 technology.
You won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice?
NO.
[ If I had my choice I would run an Nvidia 9800GT instead.
Depends on the price, and availability of the 9600GT I would assume, though.
You may also need a more powerful Power supply.
Example, not advertising,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6391081&CatId=3670 ]
Nov 03, 2010 | ASUS P5RD2-VM Motherboard
No video output from Nvidia Geforce 9600GT 512MB
run the onboard if you have one and go into the bios there's normally an option to choose what order to boot graphics devices eg. PCIE>IGP etc hope this helps.
Apr 16, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Jan 05, 2009 | BenQ FP71E 17" LCD Monitor
NO DISPLAY M2NE MOTHERBOARD
It's probably your pci-e slot of the motherboard problem. Try using different motherboard.
Sep 21, 2008 | ASUS (M2NGREEN) Motherboard
No display with ASUS M2N-E Motherboard
Repeat the procedures you learned , the exact same procedures apply to all situations
With certan motherboards you may still not see any video output
Which may mean an incompatability with the motherboard or defect
My advice is to plug in a CRT to the primary video port as a first step to getting video
Primary video port can also be the onboard video
Once you've got video you can begin the process of shutting down the onboard video and inserting
your new video card , with some motherboards if the person adds a new agp video card the system will automaticaly shut down the onboard video and use the new agp video card
BEFORE adding a new AGP video card
Don't forget to install ALL of your Microsoft Windows Critical Updates and Service Packs
because they will contain information and files that some computers require in order to function
properly with Nvidia Graphics Cards
That is especialy true of the FIC nforce2 motherboard.
You're in the zone.
Shalom >:D<
Sep 14, 2008 | Computers & Internet
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Computers & Internet Logo
413 people viewed this question
David Payne
David Payne
