Question about Proscan 26LB30QD 26 in. LCD HDTV
The screen turns on hen off
I have a proscan 26lb30q and i hooked up very thing. (just my cable box) but it urns one for about a second then turns off. Can you help?
  • kenzierosesm Jan 10, 2009
    I bought this tv for my husband who is in iraq and he has the same problem. Sears is saying since it left the states there is no longer any warranty. Poor guy is stuck with a broken tv and im out $400.
  • 2,071 Answers
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Sep 17, 2008
I have my computer hooked up to my proscan 26LB30Q. The power will come on, but it only stays on for about 30 seconds. What do should I do to make it stay powered on?
How are you interfacing your computer to the tv? HDMI? RGB video cable?? Some tv's especially Vizio's will automatically turn off if it doesn't sense a video signal on the RGB input after about 30 seconds. Make sure your computer is putting out a video signal.
Sep 24, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
What remote do I buy for the Proscan LCD 26lb30q?
Try Ebay they have them the item number is 350167917823 just type that in the top where you would put in what you want to find.
Feb 25, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30QD 26 in. LCD HDTV Logo
603 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
