Question about Canon PIXMA MX310 All-In-One Printer
Paper jam says paper jam, but no paper visible that is jammed and after i press ok, it tries to take the feed from the paper but stops and says jam, so do it again and again but not working phone. 540-250-3213 amy hurt
  • 1 more comment
  • jaskk Sep 14, 2008
    I am having the exact same problem with my printer, I do not know what to do!
  • Anonymous Sep 18, 2008
    easily said: i have the exact same problem XD. EXACT same. we contacted the service people and all and they said that it was a mechanical problem, meaning for us to take it to a service and have it checked. ~o~ in other words---apparently there's nothing we personally can do to fix it ourselves except taking it to a service.
  • Anonymous Sep 29, 2008
    Same problem here running Leopard on an iMac.
Salu béa commen sa va
Posted on Sep 14, 2008
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have a paper jam
Relax my friend,don't worry.Your printer has two major sector one is paper feed sector or other is fixing unite.it problem is fixing unite there are a sensor it is displace or broken leg.
You try to several time to open it but no success.so you need help an authorized dealer or service center.
Dec 13, 2009 | Brother DCP 7010 Multifunction Laser...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper Output Slot
Hi John,
Some small piece of paper or something stuck in the printer path, remove the paper feed tray and clean it completely , open the printer cover and clean any particles, try cleaning the printer head path also... if nothing is visible try using a torch light and then clean it from inside.... once done with all cleaning switch on the printer, things should be fine now... if not
Please get in touch with canon service center, if the printer is still in warranty, or try to contact local serive center....
Hope this answers your post, please let me know by providing your valuable feedback....
Thanks,
Robosoft.
Dec 23, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
250 people viewed this question
old marine
old marine
