Question about Dell Inspiron 1501 Notebook
Thanks why is that as i remove the battery of my laptop it doesnt open...the AC per chord that u are talking about is it the charger?thanks its a big help if u answer back Godbless:-)
    Novelist:
  • 116 Answers
Well, the battery is it's own separate module. The battery most likely will just pop out of the laptop wherever it is.
The AC cord is a power supply ran from a normal household outlet. It also charges the battery. So, you can both charge the battery and run the laptop at the same time. The battery is probably only going to be used on the run anyhow. :) So, you can just use the AC cord whenever you have access to an outlet.
Posted on Sep 14, 2008
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
My HP Pavillion laptop g61 wont turn on or off. There is no fan running it doesnt sound like it is on but the power button light is on and wont turn off. The screen just stays black. I have tried charging...
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Oct 15, 2010 | HEWLETT-PACKARD Pavilion G61631NR Notebook
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
Sep 25, 2010 | Dell Inspiron 1545 Notebook
Battery charger not working. Power adapter checks out ok. Laptop operates on battery only. 7325gz.
if it is not charging the battery will go dead.soo recharge it if it doesnt work then it could possibly be your charger.but alot of times the soldier on the input plug becomes loosened and doesnt get a connection. how did u check the chager
Oct 10, 2009 | Gateway 7325GZ Notebook
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
My nb100 doesn't turn on.. can you help me?? even if i remove the battery and i just plug the charger chord.. it still won't turn on..
Make sure the light on your ac adaptor is lit when you plug it into the wall outlet so this way you know that the ac adaptor is working properly. If you do get an led to show up then try again, if you still don't get power to the laptop then take out the hard drive and dvd drive from the laptop and try again. If you still don't get power then for sure the motherboard is bad cause that means the voltage is going thru it properly.
Jun 06, 2009 | Toshiba Computers & Internet
Thanks again...
Sometimes, the battery alarm is set to high or off and it will automatically warn you when the battery is at a certain percentage. Most newer laptops will even warn you when the battery is going bad.
The AC cord is both the power cord and it will also charge the battery when plugged in as well.
So, it's safe to run on just battery as it may just be telling you that it doesn't have AC power and that you're running only on the battery. My Satellite laptop is setup to warn you when it's only on battery power as well.
Sep 16, 2008 | Dell Inspiron 1501 Notebook
Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Apr 12, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 1501 Notebook Logo
62 people viewed this question
Alun Cox
