Samsung plasma hp-s5053 part lj41-04516A sizzled and fell off board.
  • 163 Answers
SOURCE: hp-s5053
you most have a bad conection problem, but thats a job to a tech ,dont do it your self or try to , this is a very delicate tv..good luck
Posted on Aug 07, 2006
SOURCE: remote code
I'm also same problum with Hitachi TV remote control
Posted on Mar 08, 2008
SOURCE: Samsung Plasma TV Model:HP-S5053
I had the same issues and the tech came out and replaced the main board... one way to tedt if it is the PDP is in the service menu.. run the plasam ttests and verify you don't see any dots. After replacement the tech checked all voltages and all is well.
Posted on Mar 28, 2009
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
  • 304 Answers
SOURCE: hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Posted on Jul 16, 2009
Samsung plasma clicks but does not come on
Sustain board/s fault.
Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Samsung HP-S5053 50 In. Plasma HDTV
HPS-5053 50" samsung plasma. never
The picture on this TV is controlled by a few things the most commond fail part would be one of your sustain boards. Second I would check the buffer boards. You can get parts at www.interliquidparts.com
Jun 03, 2011 | Samsung HP-S5053 Television
Hi, After 4 years long, my Plasma decided to have some blinking black the top half of the screen after watching tv for 10 min. Can you please point me to the right direction on what to replace? Many...
The first thing I would do if it were mine (and I'm a tech) and had those symptoms would be to clean the ribbon cables coming from the upper Y drive board. That's the skinny one on the left side to the left of the Y main. Be careful, if you damage the ribbon then you throw the set out. If that doesn't cure it then you can look at the Y Main. There are some small silver tin-can type capacitors towards the top that quite often go bad. If you have a cap checker that will make it a whole lot easier and faster. I can't see replacing the whole board for a few bad parts.
Dec 27, 2010 | Samsung HP-S5053 Television
Hi, My Samsung hp s5053 plasma is broke anyone can help me please!
A TV repair shop is your best bet - the problem is likely the power supply - check the fuse.
Dec 04, 2010 | Samsung HP-S5053 Television
Hp-s5053 samsung plasma with snow on hd content
Jul 16, 2009 | Samsung HP-S5053 Television
Dec 01, 2008 | Samsung HP-S5053 Television
Jul 25, 2008 | Samsung HP-S5053 Television
Green and red pixel snow
you can adjust the V-scan voltages the adjustor is on the Y-main board, locate the test point and adjust down around 15 volt
Jul 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Hp-s5053
Aug 06, 2006 | Samsung HP-S5053 Television
Televison & Video Logo
566 people viewed this question
Top Televison & Video Experts
Electro Med Services...
