Question about Jet 1HD Power Electric Wheelchair
Wheelchair support Do you have any tips for using a wheelchair safely?
    Problem Solver:
  • 5 Answers
First of all, you should be aware of your Center-of-Gravity. Many activities require the wheelchair user to reach, bend and transfer in and out of the wheelchair. These movements will cause a change to normal balance, center-of-gravity, and weight distribution of the wheelchair.
To determine and establish your particular safety limits, practice bending, reaching and transferring activities in several combinations in the presence of another individual BEFORE attempting active use of the wheelchair. roper positioning is essential for your safety.
When reaching, leaning, bending sideways or forward, it is important to use the casters as a tool to maintain stability and balance. When you are reaching, leaning and bending forward, position the casters so that they are extended away from the drive wheels and engage wheel locks.
Never attempt to reach an object if you have to move forward in the seat or pick them up from the floor by reaching between your knees. When you're reaching or bending backward, position wheelchair as close as possible to the desired object.
Position the casters so the are extended away from the drive wheels to create the longest possible wheelbase.
Reach back only as far as your arm will extend without changing your sitting position. When another person is tipping the wheelchair, he should grasp the back of the wheelchair on a non-removable part.
Inform the wheelchair occupant before tipping the wheelchair and remind them to lean back.
Be sure the occupant's feet and hands are clear of all wheels and/or any other pinch points.
Posted on Sep 14, 2008
I want to know how to safely secure a wheelchair into this car
sorry but we do not know what type vehicle you ask for .
Nov 02, 2015 | Cars & Trucks
The black rubber top for the rubber joystick on my wheelchair keeps falling off where can I purchase a new one? It looks like a black rubber nipple
superglue holds rubber to metal very well , just don't use to much to run down inside switch but stays on tip
they now mfg a gel superglue for this very application (no run/no mess)
Jun 01, 2015 | Health & Beauty
What can i do to speed upp chair?
1. Use the buttons or dial on the joystick to adjust speeds.
2. Use the programmer to reprogram the top speed- which will be about 4mph. This is a pretty typical top speed on low-end wheelchairs. Remember, speed affects performance- the faster you go, the worse the braking and turning gets, and the tippier the chair gets.Also remember that wheelchairs have very few safety features for crashes and tips.
3. Invest in a pair of high performance motors and motor controller (which probably means a new joystick, too). You'll also need better batteries since the faster speeds will put more demand on them. Your best source for this sort of information will be wheelchair user forums.
4. Buy a high performance wheelchair, like the Bounder High Performance (http://www.wheelchairs.com/fast.htm)
Most people who use chairs want more speed, but wheelchairs are TIGHTLY regulated by the government, and there are lots of restrictions on what they can and cannot do.
May 20, 2014 | Pride Jazzy 1103 Ultra Standard Power...
How to safely use detecto 3pramp wheelchair ramp
manufacturer should have video online or dvd to send you
Nov 28, 2012 | Detecto 3PRAmp Wheelchair Ramp for...
Wheelchairs don't have a neck support. they do have "head rests" that people label "neck supporters" but really aren't.is their any one that agrees that this is a problem?
There is usually a "universal" headrest that is used to try and make things simple as there are hundreds of parts to keep track of, espcecially when it comes to rehab devices. The headrest is pretty utilitarian so it can be used for a wide range of conditions which makes it great from some folks and barely adequete for others. Most people think of headrests like the one in a car, instead of just the basic semi-circle that they end up with. If the headrest isn't supoprting you right, you might want to follow up to see if any adjustments can be made to your seating to ensure you can operate your wheelchair safely and comfortably.
Oct 07, 2010 | Health & Beauty
Someone gave me a pronto m51 sure step motorized wheelchair but no manual was given..my question is: Is it safe to charge the battery overnight? Is there any danger of overcharging? If anyone knows for...
Jo, nope you are safe. Most of the chargers are designed to cut off and go into trickle charge once they sense that the batteries are fully charged. The problem with overcharging comes after 18 hours or so. You should never leave the charger plugged into the chair for more than 24 hours. On the M51 the charger is built into the chair so just plug it in when you go to bed and unplug it when you get up and you'll be ok. You can check for full charge by looking at the charger there should be a red light and a green light when fully charged. Hope this helps
Sep 08, 2010 | Invacare Supply Group Invacare Pronto M51...
Got a used one.charged it.the horn is the only thing that works
From past experience, more than likely the carbon tips on the rubber keypad that make the contact on the circuit board may be degraded to the point that they no longer make contact.
May 20, 2010 | NRS Hoveround MPV 5 - Used Power...
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Mar 28, 2009 | Invacare Supply Group Invacare Pronto M51...
Wheelchair tips
Here are some tips
  • When booking your flight: Use a travel agent who is experienced with planning trips for travelers with disabilities.
  • Make your reservation far in advance.
  • If possible, choose an airline with planes that have 30 seats or more - larger planes offer more accessibility.
  • Pick a flight with no changeovers. Call ahead to alert the reservation clerk that you will be traveling with a wheelchair.
  • Arrange for boarding assistance or an aisle chair to get to your seat. And if you can't walk, request an aisle chair during your flight for bathroom use.
  • You should arrive at the airport At least an hour in advance so you can store your fold-up wheelchair on-board. (There is usually room for one wheelchair on a first-come basis).
  • When possible, use gel batteries, as wet batteries must be removed and stored in a separate sealed container.
Sep 14, 2008 | Excel 3000 Wheelchairs Removable Desk...
Jet 1HD Power Electric Wheelchair Logo
634 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
