Question about GE Security Simon 3 Wireless Home Security System
Motion Sensor How do you replace the battery?
  • 3 Answers
Open the back cover, and then pull the component out. there are two AA batteries.
Posted on Oct 05, 2008
How do I replace a low battery in motion detector for my Honeywell wireless alarm system?
Look on the bottom of the sensor, there is a tab/button press it in and pull outwards from the bottom of the sensor, it will hinge upwards and detach.
Inside you will see the battery which is easy to change..
Replace the battery - refit the sensor top first and push in at the base, Job Done.
Jan 23, 2017 | Honeywell Home Security
Battery in ademco 998pi
It could possible be your main battery in the panel.
Apr 11, 2014 | Honeywell 998pi 998 Motion Detectors Pet...
Change battery ws4904p
First, make sure you have the correct replacement battery. Go ahead and get a Lithium CR123A battery. These are rather expensive at retail, so do yourself a favor and get as many as you need at an online source such as Amazon. These sensors require one battery. The DSC glass break sensors in our home required two. Our glass break sensor went out within a week of the motion sensor, so I just replaced all of them. YMMV.
Second, determine which way the sensor is housed in the, uh, housing. The "bottom" will have a small tab with a circle in the middle, like the picture below.
As you can see from my incredimazing MS Paint skillz, use your knuckles to gently tap the sensor away from the tab. It should pop right off. This can be annoying if you don't have lightning speed and cat-like reflexes to prevent it from falling behind the entertainment center.
Once the sensor is removed from the housing, push the battery cover off of the battery compartment. Remove the old battery, and install the replacement in the same direction. Put the cover back on, and then align the sensor in the housing until it is flush with the bottom part of the housing. Remember to recycle the old battery if at all possible. Good luck!
Sep 12, 2013 | DSC Ws4904p Wireless Motion Detector...
Ds 924 motion detector
It may have been previously learned into a zone. Sometimes, the motion will trip and activate a signal that can be learned into another zone you are trying to program. exit programming, then "tamper" the cover for the circuit board, not the battery access, on the motion, check the "status" light to see if a zone is displaying "tamper". Also check battery orientation in back of motion. When battery is first installed correctly. The light should activate during the first minute.
Sep 15, 2017 | GE 60-511-01-95R - ITI Wireless DS 924...
I have this light for 2 years with no problems at all. recently, it seems that the "left side" of the sensor stopped working. (If I walk right in front or in the right side, the lights will come...
  1. Locate the sensor on the motion detector. The most common problem with a motion detector is a sensor that is obstructed or dirty. Remove any dirt, grime or anything else that may be blocking the view of the sensor. If you need to actually touch the sensor itself to clean it, use a soft cloth or cotton swabs.
  2. Determine if the motion detector has electricity running through it properly. Connect an electrical meter to the wires from the sensor itself. If electricity is indeed running to the sensor, you likely have a broken senor. If there is no electricity making it to the sensor, your motion detector has an electrical short. In the case of an electrical short, you will need the help of a professional electrician to fix it.
  3. Visit a hardware or supply store to buy a replacement sensor
Thanks for understanding.
Nov 16, 2011 | Heath Zenith All Metal Motion Sensor Light...
I replaced the batteries in the motion sensor and now it appears that I need to learn how to adjust the timing. Is there a manual for the 270 (I think this is the one from the picture)?
there is a slide switch on the bottom of the sensor......test....1 min.....5min...
u may have to reset the sensor....turn power off .....then remove batteries.....wait 5 min....then turn on power....then replace batteries ......do not move the sensor and wait 1.5 minutes...
U can also call heath zenith @ 800 858-8501 and talk to tech support....
Jan 24, 2011 | Heath Zenith 270 Degree Replacement Motion...
Hello, I have a Sportline Digital Motion Sensor.
Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
Make sure the battery is inserted with the positivet side up?
Manual is here: http://www.sportline.com/manuals/370.pdf
Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
My sensor no longer works. It use to turn on the porch light when someone entered the carporch. How do I open the sensor so that I can put new batteries in it? I know that it uses AAA batteries.
Manual for this sensor is not available.
In the Zenith I have installed The motion sensor battery slot was h at the back side of the sensor, you had to remove the sensor from the wall sliding it on one side to access the battery. It mounted two AA batteries, not AAA.
Aug 17, 2010 | Heath Zenith 270 Degree Replacement Motion...
Motion sensor wasn't working, replaced battery. Now says sensor tampered. How do I reset
In your motion there is a tamper switch. make shure your caver was properly installed.
at the panel enter your code as you would to disarm your system and repeat disarming a second time.
Nov 07, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
114 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
