I bought a kenwood kaf1010, powers up fine all buttons and l.e.d.s fine, believe it has input from cd player to volume control as my elec tester picks some thing up. but nothing to the speakers. took cd player and speakers from my set up in use now. so i know its not them. amp makes a clicks noise when switched on as it should and clicks off as well. checked for power in and checked fuses its something on the output, is it best to buy new board, or diode, ect, could you shine some light on the sittuation. thanks
  • 822 Answers
Suggest connecting headsets. If audio is present then you can assume the problem is in the final stage of the power amplification. Also you can check the record out using another amplifier to confirm preamp is OK.
If all speakers are not workinhg check the power supply that feeds the power amplifier for spealers.
Hope this helps.
i bought a kenwood kaf1010, - kenwood-kaf-1010-144842-efqr1tkyxkjjaeu2rzas4dg3-2-0.jpg Hope this helps?
Posted on May 17, 2017
the dr
  • 447 Answers
SOURCE: MAYTAG DRYER MDE5500AYW
Have you checked the door switch, thermal fuse on the heater housing(this will keep it from starting).
Posted on Oct 06, 2007
yeokeke
  • 5 Answers
SOURCE: Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Posted on Nov 24, 2007
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
Receiver Not Working Properly with MB-2 CD
I believe your supposition is correct although I think your CD player is unusual if it has variable (audio) output. Most players have only low level output.
Dec 20, 2013 | Nakamichi RE-1 Receiver
I cant hook up my mp3 player up to my kenwood cd player!!! i bought the hook up too and i still cant
select the auxillary input display and push the control knob left or right until you see portable, then you should be able to play your mp3 device
Mar 28, 2011 | Kenwood KDC-MP235 CD Player
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Schoche.com Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
http://stereophonik.com/gutterslide/IP-BUS_Hack/
Oct 07, 2008 | Pioneer DEH-P3100 CD Player
JVC KD-G322 Demo mode
Hold down the "SEL" button, and use the CD track skip button to scroll to where the display says "DEMO," and use the volume knob to change the setting to "OFF." Push SEL again and you're good to go.
Apr 03, 2008 | Kenwood KVT-617DVD Car DVD Player
Switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Nov 12, 2007 | Kenwood eXcelon KDC-X579 CD Player
Code
try display button and volume button to get the point to enter the number. Try 1234 or 5021
Oct 20, 2007 | Kenwood KDC-MP4028 CD Player
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
66 people viewed this question
 Grubhead
Grubhead
