Question about Dryers
Frigidaire Dryer (Electrolux Model LER331050) won't heat
4 Suggested Answers
  • 1122 Answers
SOURCE: how do i change the heating element in my dryer
it's way to hard afor a lay person,call for repair-mike
Posted on Jun 19, 2009
Maytag317
  • 1136 Answers
SOURCE: CHANGING DRYER CORD
All you need to do is, attach the middle connection from the cord to the middle post on the dryer. The 2 outside connections on the cord will attach to the outside posts on the dryer. It does not matter on the outside connectors as far as which side they go.
Make sure they are fastened down tight. If the connections are loose at all, they will go bad.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 23, 2009
apexappli795
  • 46 Answers
SOURCE: IT WILL NOT HEAT. how do i remove the heating element to replace
Is it gas or electric? It could have a bad timer, heating element, power problem, circuit breaker could have tripped, or blown fuse or burnt wires inside dryer. I believe the top pops off from inserting a screw driver between the top and front dryer frame and pushing in 2 clamps located near each side. Then the front unscrews from the inside. Or a bottom panel might come off same way underneath the door.
Posted on Sep 16, 2009
Frigidaire Electrolux aeq6000es1 heats but sometimes doesn't heat when drying clothes why is this happening
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dryer heats and will occasionally not heat when drying the cloths. This could be a possible issue with your thermostat or control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord from it for at least ten minutes. If that does not help resolve your issue you may need to have a professional technician out to perform a proper diagnosis and repair. This will help your avoid any unnecessary part purchases. -Matt
Dec 28, 2015 | Frigidaire Dryers
How to replace heating element on frigidaire fase7073lao dryer?
Takes Frigidaire (OEM) Part #134792700
http://www.ebay.com/itm/134792700-NEW-Genuine-Electrolux-Frigidaire-Kenmore-Dryer-Heating-Element-OEM-/181461935813?pt=LH_DefaultDomain_0&hash=item2a3ff966c5
~ $87 w/free shipping
Here's more pix on YouTube. Get your screwdriver out and go at it. You'll never learn any younger. Write down and/or label where EACH wire goes as you disassemble. Just remember SAFETY FIRST. NO POWER while you're working on this ! UNPLUG is enough, there is no residual voltage on a dryer. Best help may be on YouTube. ask for (type in) Frigidaire Electric Dryer repair. There are several videos, one of which should serve to give you courage and a starting point if you've never done it before.
Jul 20, 2014 | Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
2 different parts and prices for my dryer
Go online and look for an appliance store in your area. Get you dryer model number and as much information Possible and buy what you need. Good luck
Nov 21, 2013 | Electrolux Frigidaire Washer & Dryer...
Electrolux Dryer Heating Element 131553900 is this the right one for model #fex831cs0 or can you restring the original if so what is that part Number
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
Mar 18, 2013 | Frigidaire FEX831CS Top Load Stacked...
CHANGING DRYER CORD
Thanks
Vic
Jul 23, 2009 | Frigidaire GLEQ2152ES Electric Dryer
How do i change the heating element in my dryer
Jun 19, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
194 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
