I have a CYTRON PD7018 DVD Player. It Displays "NO DISC" when ever I load a DVD.
5 Suggested Answers
SOURCE: displays no disc
I had the exact same problem. When I finally opened the top there was another disk already in there. I guess if the unit shuts off and you leave aa disk in it will stay in the player even though when you open the door to place another disk in the tray will be empty. All you have to do is unscrew the cover aand then you will see a crossbar held in with two screws where the disks are. unscrew them and take out the two disks thay are stuck togeather. Replace eveything and rescrew and enjoy the movie!! Hope this helps!
Posted on Feb 08, 2009
  • 524 Answers
SOURCE: dvd player says no disc when there is a disc in
Hi
Please check weather you have inserted the disc ,whose format is supported by your KOSS player.
If the formatt is not been supported /regonised by the player,It shows as NO DISC only.
check with some other disc which you previously played.If it plays the disc which you using has the problem.
Thanx
Posted on Jul 26, 2010
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
jdvillanueva
  • 2098 Answers
SOURCE: My DVD player keeps
Diagnosing the fauty parts on dvd player is quite technical but i will suggest a diy solution that may help you on your problem.
Try cleaning the Lens of your DVD(It might be covered by dust thats why it can't read any disc) by a soft cotton bud. Be careful while doing these and try if it will work.
If the problem is still there then i've advice you to send it to repair shop to replace the faulty parts.
Thanks for using fixya.
Posted on Jan 09, 2011
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Hi,my sony DVP-NS51P Keeps loading when a disc is inserted,then finally displays "CANNOT PLAY,CANNOT.Please help.
The laser assembly is defective. It can be replaced, but is somewhat challenging and the part usually cost between $45-90 USD.
Jul 11, 2011 | Sony DVP-NS51P DVD Player
DVD does not recognize any disk. "No Disk" displays after constant "loading."
if you can open your dvd player casing, try to clean the lens or you can buy a cd lens cleaner at any DIY or computer shop
May 22, 2011 | Philips DVP5140/37 DVD Player
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
Can't Read Disc
Jul 06, 2010 | Philips DVP5990 DVD Player
THE PLAYER DISPLAYS BAD DISC.
You have not said the TYPE of CD or DVD you are trying to play.
Your manual will clearly state what can be played and what cannot. ALSO, some mfg's like mine (samsung blu-ray) provided software or firmware updates you can d/l to flash drive or burn on cd and insert.
Check manual and your mfg websit for what's available.
May 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
