I have a Brother 2070N with a paper jam. I tried to pull the paper out from the back, which I opened, and it tore off at the roller and now there is nothing to get hold of. How do I get in there to get it out?
Contacted the manufacturer on the internet and they had the procedure to clear the paper jam which worked. Thanks for the interest.
Posted on Sep 15, 2008
Paper feed only works manual
I think you have a paper jam or some other tiny objects like a paper clip or the like blocking the ADF(Automatic Document Feeder) roller. You should open your ADF and check for anything obstructing the roller. If you see something just pull it off close the ADF and turn on the printer.
Good luck,
Sai.
Dec 02, 2009 | Brother HL-2070N Laser Printer
Paper keep jamming
You don't say where the jam occurs but if there are no obstructions, the rollers need to be replaced. The paper buffs these rollers (rubber) smooth so that they no longer can grab. Sort of like tires wearing out on a car.
Aug 01, 2009 | Brother HL-2070N Laser Printer
Paper jammed in my 2070N printer & I don't know how to remove it
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Jul 22, 2009 | Brother HL-2070N Printer
Paper jam repeatedly
Possible cause:
The eject rollers get too slippery because of paper dust and other foreign matter.
Recommendation:
Clean the eject rollers with a paper towel dampened with water. A second cleaning may be
necessary. The easiest way to do this (without disassembling the machine for full access to
the rollers) is to hold the dampened paper towel against the rollers and make a blank print.
Clean the rollers as they turn and remove the paper towel as the paper ejects. Repeat as
necessary.
Now is a good time to also clean the paper pick up roller and feed rollers to prevent
feeding problems.
Jun 18, 2009 | Brother HL-2070N Laser Printer
Paper jam
Please open the front cover and remove the drum to check the jam. If not in the drum, then check the back cover, open it to remove any jammed.
May 12, 2009 | Brother HL-2070N Printer
How do I remove paper from paper jam?
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
Paper is jammed half way out on HL 2070N model
open the rear access door and pull the paper backwards through it then firmly and smoothly pull the paper free ofrom the fuser. pull the paper straight. should be easy.
Apr 08, 2009 | Brother HL-2070N Laser Printer
Paper jam
reset by unplugging and then plugging back in, also make sure no paper is stuck in the rollers on top or the back....make sure all rollers are free of dust and if they have dust wipe off.....make sure you using the right type of paper and the printer itself isn't dirty....hope this helps
Apr 06, 2009 | Brother HL-2070N Printer
Torn paper jam Brother mfc 440cn
I pull paper out to remove it too, no worries, who doesn't.
You may be able to open the back of the unit up and there are a few rollers there than can be manipulated. Make sure it's unplugged. Don't force too hard but a little push or pull wont hurt.
Try rolling all the rollers that are in reach to see if you find anything, and they may need to be cleaned a little (not with anything wet!) with your finger is fine...they collect paper dust. You can blow in any area to try and clear any other paper dust also.
Let me know if this helps.
Jan 26, 2009 | Brother MFC-440CN InkJet Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
k24674
