Question about Kenmore Dryers
Heating Problem Our dryer will heat for about a couple of minutes and then quits heating. After about and hour, it will heat again for several minutes and then quit. There is ocassionally a metal noise as it runs.
  • 88 Answers
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Posted on Sep 14, 2008
How can I get my dryer to heat up again? Its a model # 417.88042700
Whirlpool Dryer Not Heating ' U-FIX-IT ' Troubleshooting > Repair Tips
The heating element in my dryer heats up and the. Turns off with 2 minutes. ...... I have to let it sit for 2-3 hours for it to heat again and even this is not consistent.
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
Jun 4, 2010 - Uploaded by eSpares
Dryer problems: How to fix a dryer that's not heating up ... went to look for a video to fix my dryer... and as ...
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
Oct 6, 2011 - Uploaded by PartSelect
In this how to video you'll learn why your dryer might not beheating properly. Remember ... Up next ...
How to clean your clothes dryer. How to make it hot again ...
? 8:36
Jan 26, 2010 - Uploaded by askmediy
Also visit my site for more detail and please ask your quest... ... How to Fix YOUR gas Dryer that is not heating ...
Jan 04, 2016 | Dryers
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
It quits heating after a couple minutes and sounds
replace the fan otherwise your microwave cell wil burn out, the safety comes on because the cell become to hot. no colling of microwave cell.
Feb 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Dryer Heats for 30 Minutes then stops heating
Hello there :
what you are going to want to do is to troubleshoot the heating circuit
if you have a multimeter
there is a thermal Cut-Out switch that is connected to the heater box.) -simply unplug wires and take reading from the end connetors
your reading should be 0 ohms. and nothing else
Next check
a part called the Hi-Limit Thermostat that is connected to the heater box, it should be located closest to the heating element wire leads unplug the wires and take the reading across the 2 wire connections . this should give you a reading of 0 ohms and nothing else.
Now if any of these 2 parts are not in this range they need to be replaced and i would recommend that you replace them as a set cause if one usually goes out then the other one will soon follow ok
I hope this is very helpful for you
Best regards Michael
Jan 09, 2010 | Kenmore Dryers
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Dryer stops after a while
it's over-heating it needs to be looked at, thermal fuses, lint buildup
Mar 24, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
177 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
