Question about Wurlitzer Jukebox CD Player
Number selsctions Hello; When you make a selection, for instance 1205, most of the time, not all the time, it will play 2 off,eg 1203 or 1207. Any help would be greatly appreciated. Also, what type wire do you use between the remote and the jukebox? Thanks for your time
    Champion:
  • Wurlitzer Expert
  • 211 Answers
I'm not sure what jukebox you are referring to but if it uses a Selection and Credit Computer (SCC) it sounds like it is faulty.
What machine is it?
Posted on Nov 12, 2008
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
I can't find my printer when you select a printer from the printer options
Please make sure that you have installed necessary drivers for your printer. If you have not installed any drivers, then you download the driver by visiting the link below and selecting your computer operating system.
HP PSC 1205 drivers
If this does not solve your issue, then please revert back.
Aug 24, 2011 | HP PSC 1205 InkJet Printer
Using my Nokia C6 phone , How i can delete a single entry from my call leg rather than delete the whole entries. for example how delete a single number from the recieved or dialed numbers?
Its easy. Just go to that call log. For instance, you want to delete XYZ's number from the received calls log, go to you recieved calls, scroll to XYZ, select 'options'. In the options, select 'delete'. You would be asked if you actually want to delete the number XYZ from the received calls log. Selecting 'yes' deletes the number.
You can do the same for your dialled and missed calls.
Hope that helped you?
Have a wonderful day.
Jun 20, 2011 | Nokia C6 Smartphone
We have a Utilitech timer and can't program to come on or off Please advise...
I bought a Utilitech 2-outlet timer #0155671 last year and have lost the instructions. I was playing around with it today, trying to program it. My screen was blank because it had sat dormant over the last year. This can be remedied by plugging the unit in to recharge the internal battery and pushing the reset button on the front.
Here'e how I programmed the unit. To set the day/time; press and hold the "clock" button then press the "day" button once to advance the arrow at the top of the digital screen to the correct day. Continue to hold the "clock" button while pressing the "hours" button to cycle to the appropriate time. The AM / PM indicator changes automatically as you cycle through the hours. Do the same thing for the "min" button to set the appropriate minute.
It appears that there are 9 different on/off times that can be set in the unit. The timer number is in the lower left corner of the digital screen. Each time one pushes the "prog" button a separate "on" time, then "off" time is selected for each of the 9 instances. Press "prog" to select the desired timer instance (either an "on" of an "off"). Press the 'Day" button to toggle through several different day settings. These are specified by arrows under different days at the top of the digital screen. Then press the "hours" button to select the appropriate hour and the "min" button to select the appropriate minute. Press "prog" again and the "off" instance for that timer setting is selected. Use the hour and min buttons to set off times. Pressing the "Prog" button again will select the next on/off timer instance for programming.
Hopefully you can follow these rudimentary, somewhat confusing instructions.
Nov 10, 2010 | Computers & Internet
Need a manual for altech althc014. have no idea how to use it. can't work out how to just turn on without the timer!!
Ive been having the same problem! I found these instructions on a forum if it helps-
To Set the Temperature
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
How do I set the time and date on my Salus programmer?
· Press the Set and Select buttons simultaneously to enter the clock setting mode.
· By using the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock. Once selected press "SELECT".
· The "HOUR" will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the desired time. Press "SELECT".
· With the "MINUTES" now flashing adjust with the arrow keys to the correct minutes. Press "SELECT".
· Now the "YEAR" will need adjusting. Again use the arrow keys to change and press "SELECT".
· Now adjust the "MONTH" with the arrow keys and press "SELECT"
· Next to change will be the "DAY OF THE MONTH" again with the arrow keys change and press "SELECT"
· "dLS" will now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF" use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Sep 27, 2010 | Heating & Cooling
Hello, I can't get sound to my laptop. when I go into the sound controls it's set for Internal but doesn't give me the option to change it?
Check the Sound driver in Device Manager.
Obtain and install the update Sound driver from drivers page.
Open www.hp.com type the product number (eg: AB123UA) in the search field >> Software and Drivers >> Select OS >> Audio driver and isntall it. Restart.
Next...
Restart Audi service
1. Windows key+R. services.msc and press enter.
2. In the right pane, double click on Windows Audi.
3. Stop and then Start. Select Startuptype: Automatic.
4. Apply | Ok.
Next...
Connect an external headphone and check for sound, if working.....
Connect External Headphone.
Play some musich and as soon as the Music starts
Removet he headphone with a slight ****. Check if sound coming from Speaker.
Next...
re-install OS
Next..
Repair
Jul 24, 2010 | HP Computers & Internet
Firefox is playing in background what do i do
In windows:
1) Press ctrl+alt+del, task manager will open.
2) In the task manager, select the running firefox instance.
3) Press "End Task"
4) Now you can open a new firefox instance.
In ubuntu:
1) sudo killall -9 firefox.
2) Now you can open a new firefox instance.
May 19, 2010 | Mozilla Firefox
Playing songs on my dsi
Hello subodhkelana
1. Insert your SD card into your PC/Mac/external card reader/writer.
2. Open Windows Explorer (PC)/Finder (Mac), and select the drive being used by the card to open it.
3. Open another instance of Windows Explorer/Finder, and navigate to where your music is stored.
4. Highlight the desired file(s) and/or folder(s), copy them, and then paste them into the first instance of Windows Explorer/Finder to create copies on your card.
Hope this helps. Please don't hesitate too contact me should you require any further assistance.
ajblaj
May 08, 2010 | Nintendo DSi White Console
Printer HP psc 1205 incompatible with Vista
Follow this link and see the availability of drivers for your printer. Just type your printer model and search (Eg laserjet 1200 )
or copy and paste this link to your another window of the browser
http://www.hp.com/#Support
Oct 10, 2009 | HP PSC 1205 InkJet Printer
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
55 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
