THE click is the relay on the power board coming on and then going off---red power light should blink a error code---when set shuts off (second click) watch the power light and count the blinks.
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need. http://servicemanuals.vstore.ca/
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
8 blinks is usually the error for a bad flyback. you can get a replacement at the following link and if your not sure which one your model uses click on the sony flybacks one at a time and it will tell which model they fit. Heres the link. http://servicemanuals.vstore.ca/
I would suggest to turn the screen control potentiometer down a bit, this control is found on the front of your TV nearby the CRTs.
The part looks similar to the picture. Click here to see picture.
The red control is the one on the left if you are facing it.
Let me know if you need further assistance.
8 blinks in that model means High Voltage Error which means the flyback is defective and will need to be replaced. Sony parts list it as no longer available. But you can get it at the following link for 129.95 and it comes with free instalation instructions. the job takes about 45 minutes from start to finish. Heres the link. http://servicemanuals.vstore.ca/
your set is shutdown for protection due to an audio malfunction in the audio circuits. heres the info for your model from the service manual.
• + or - 22V audio supply is not
present—Check PS600 & PS601
• Audio AMP is damaged IC601 on
A Board
eight blinks means, "High-voltage error" and the probable cause
location listed is, "T8005 is faulty (D board)". T8005 is the fly-back
transformer assembly.
