Question about LG 47LC7DF 47 in. LCD HDTV
47LC7DF The green light goes on when I power it up, no other response. No picture or sound on ANY input. There is a delay of 5 to 10 seconds when powering on or off. Set is about 11 months in usage now. No problems noticed until today.
  • programmer04 Jan 05, 2009
    My TV (exact same model) was roughly the same age when it started doing the same thing. I bought it at the end of January and the problem started around Christmas. Normally, the power light would flash green about 5 times before the picture and sound came on. Now, it flashes 18 times and all I end up with is the back lights on but no picture or audio and it takes several seconds to power off. It can take anywhere between 20 minutes to over an hour of turning the TV on and off before it starts working again. I unplugged it for a few minutes to reset it as an LG Tech suggested, but it didn't help. Now I'm afraid to turn it off as it might not come back on. I have about 3 weeks left before the 1 year warranty runs out, so I guess I'll have to go that route.
  • Anonymous Apr 23, 2009
    I have the same problem with my LG 47 inch. It is still under warranty, so is it best to have a tech come out and replace whatever is causing the problem or does removing the power overnight take care of the issue? I don't want a temporary fix that will recurr if I don't have it taken care of with new parts. What do you think?
  • LG Master
  • 5,568 Answers
When problems arise that kill both video and audio, it is normally related to the failure of the main power supply.
Nearly all modern electronics uses a 'switched mode power supply.'
They are more efficient while being much more complex and prone to failure but offer the added benefit of being designed so a 'downstream' fault will cause the supply to shut down to avoid setting fire to your home.
The supply itself will also cycle if it has an internal problem; once again, to prevent destroying itself or anything dependent on its outputs.
Supplies built a couple decades ago could only do this by blowing a fuse and there are conditions that can occur that would not blow the fuse but would allow overheating and further damage as well as fire.
You might try the following: Pull the AC plug from the wall and ignore the set for a day or overnight, then plug it back in.
There are literally millions of semiconductors in a modern TV receiver and sometimes, they trip and lock themselves up.
When that happens, removing all power from the unit will allow everything to return to a stable state and function as designed again.
If that doesn't help, I hope your set is still under warranty as this could be a multiple hundreds of dollars to repair.
The power supply is often on a separate board and unfortunately, component-level technicians aren't that common anymore so frequently, the board is replaced and the old one discarded.
Posted on Sep 14, 2008
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Lg 47lc7df tv blinks green light, no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 27, 2017 | LG 47LC7DF 47 in. LCD HDTV
I have an LG 47LC7DF and I only get a red light when the power is off and when I turn the power on, the green light flashes a few times and then stays on. I do not have a picture or sound. Please advise...
Red light means your tv is in the stand-by mode..There could be serveral problems? Like your Y main board,T con,Upper & Lower buffer..Need to have a professional take a look ...
Sep 17, 2011 | LG 47LC7DF 47 in. LCD HDTV
Have a LG 47LC7DF tv and its starting to have a hard time turning on. Green light flashes for 15 secs and screen lights up a little with no picture or sound. Have to unplug it to shut it off sometimes....
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this work out in solving the problem.....
Jul 05, 2011 | LG 47LC7DF 47 in. LCD HDTV
47LC7DF, Green light comes on, blinks with remote
When you say that you have replaced the main board i assume you mean the power board? If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can buy these online probably the same place you got your new mainboard from. Hope this helps pls post bach what happens.
Feb 01, 2010 | LG 47LC7DF 47 in. LCD HDTV
No picture or sound GV47LF
Buy parts for replacement like capacitors,or board.
Ur backlight video inverter board is dead.Tries these
Websites Shopjimmy.com or Ebay.com.
Sep 29, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
Well dont keep it on!
By running it after it shutdown and it finally did its last pop that added another $XX to the parts bill.
The control boards (2) have now failed There are burned Capacitors ( pop!) and possibly even a few transistors burned out. This is not a DIY it is a Tech job as once changed these boards require additional tuning of the convergence factor.
Aug 31, 2009 | LG 47LC7DF 47 in. LCD HDTV
No picture no sound
seems to be common faults with this model in LG there have been a number of their models recalled to fix power board and the video controllers
Aug 19, 2009 | LG 47LC7DF 47 in. LCD HDTV
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
LG 47LC7DF 47 in. LCD HDTV Logo
359 people viewed this question
Computer Repairing
Computer Repairing
