Question about Kenmore 62702 Microwave Oven
Night light won`t work.Was changing bulb and heard a pop.Replaced bulb,still won`t work.
  • headhunter2 Oct 25, 2008
    Hello, I have a GE JVM1860 that has two halogen bulbs underneath. The bright setting works both bulbs, however the nite light setting does not illuminate either bulb. The rest of the features function as normal.
  • adipuzha May 11, 2010
    How to change a fused bulb
  • Kenmore Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
JVM1340WW 003 heard pop now bottom lights do not work.
MAKE this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 01, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
I replaced the outside/night lights on my Kenmore microwave and the lights stay on. They are 3 settings, high, night and off and they do not cycle through, they are always on and won't shut off
This is a shorted relay on the control circuit board, which we normally repair for $39.95 nationwide.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 17, 2011 | Kenmore 63792 Microwave Oven
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
Heard a pop and the underlight quit woking
change the bulb and see if their is a reset button for the light
does the oven still work
Jan 10, 2010 | Kenmore 62622 Microwave Oven
Heard a "POP" and both lights went out. Replaced bulbs and still, No Lights".
You most likely have a blown fuse. The fuse is located inside the case at the top and likely to the left.
Sep 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Kenmore 62702 Microwave Oven Logo
284 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
