Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Loud noise when the water button is depressed.
When the water button is depressed and someone trys to get some water, there is a loud noise coming from inside and no water comes out. I have checked the water line and the filter, both seem to be ok??
  • wksawyer1 Sep 14, 2008
    Harvey,
    Thanks so much, I will check that out. I really appreciate it!!!
  • janice Langston Sep 10, 2013
    how do know if the valve is bad
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi wksawyer1,
I'm Harvey the Master Plumber.
Your problem is: When the water button is depressed and someone trys to get some water, there is a loud noise coming from inside and no water comes out.You have checked the water line and the filter, both seem to be ok??
Sounds like you might have a bad solanoid valve. It's in the back where the water line hooks up. Check that out.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • Harvey Goldberg Sep 14, 2008
    Hi again,
    Glad to be of service.
    Harvey
LOUD VIBRATION NOISE COMNG FROM FRIDGE WHEN WATER BUTTON DEPRESSED. ALSO NOISE COMES RANDOMLY THROUGHOUT DAY. WATER LINE IS NOT FLOWING WATER EITERH..
It's the solenoid on the water valve. Power is getting to it but it's not opening so it just sounds like a buzzer. It's usually located in the back on the bottom where the water source enters the appliance.
Sep 13, 2015 | Refrigerators
Loud noise when cooking
I had an arcing sound coming from above the cardboard panel inside the microwave. When I saw it sparking I took the cover off and saw that these two aluminum looking things had come loose. I removed the cover and did a fair bit of 'fine tuning' to get it working again.
Apr 03, 2014 | KitchenAid KHMS2050SSS Microwave Oven
2005 freestar 4.2l, chirp noise on engine located behind water pump..take off the belt and the noise continue...
I knew someone with a Ford Taurus that had the same loud chirp like a loud bird. That turned out to be the cam shaft sensor assembly if memory serves me right.
Sep 15, 2013 | 2005 Ford Freestar
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
My radio transmitts fine. But when I key another CB, my CB makes a loud noise as it trys to receive. Plz help.
hello what do you mean by a loud noise ,how close are you when you key another radio please try and give more info i will help you the best i can
Jan 09, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
The water to the ice maker continues to drip then freezes up.
the loud noise is from the water freezing and hitting the fan blade in the freezer, is the imkr level? have you replace the filter if has one? is it hooked to an R/O water drinking system? if so remove the filter in frig. last thing to do if others questions ok if the shutoff to that water line going to frig is on the bottom of the pipe shut all the way off then turn back on if you have a dispenser and water is really slow to come out this may clear up the low water pressure. If on most units if you do not have appx 35psi it will not allow the valve inside the watervalve to seat and allows water to dribble by
Sep 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Well-Rite WR240R makes loud noise every time water flows into it
Tank may be air bound. There is an air valve on top of tank. Take cap off and depress valve momentarily. If water comes out of valve, the bladder is torn, and new tank is needed. If no water comes out, check the pre -charge pressure of tank.
First, run water in house and take note of the on-off pressure of your pump. There should be a water pressure gauge on the water line going into the tank. Take note of the cut on pressure and cut off pressure. Most well systems typically operate at 20-40, 30-50 lbs of pressure. Next,shut off electric to pump. Drain all water from tank. Take a tire gauge and check air pressure of tank. The static or pre-charge pressure should be two lbs less than the cut-on pressure,i.e if your system operates at 30-50, then the pre-charge pressure should be at 28lbs. Adjust pressure as needed. A small air compressor is ideal to use if more pressure is needed.
Jul 15, 2009 | Plumbing
Drum turns slow and makes a loud noise
Check for a garment stuck between the tubs.
Check the direct drive coupling on the motor.
You must remove the cabinet to do this.
Mar 05, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
234 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
