The microwave shut off by itself. Is there an auto shut off? I ask because I was reheating some squash and the microwave shut off. No lights nothing.
Sugestions?
Re: The microwave shut off by itself. Is there an auto...
Check it after 2 hrs .By repluging it. If you use microwave alot then it might get too hot,So just try it. Otherwise give some more detail to me to trouble shoot it. Thanks
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
2)Remove the louver by removing the three Hood Louver Screws.
3)Push in the upper tabs and pull the louver away from your appliance.
4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
If you are trying to change the light bulbs underneath your Microwave:
1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
2)To open Light Cover, remove the screw on the light cover.
3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
4)Close the Light Cover and secure with screw removed at step 2.
If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
try unplugging it. or the probe might be defective. another trick is slamming the door when shutting it, if this works it;s a micro switch thats gone bad or out of alignment
It will reheat depending on the weight or type of food (usually weight) . If it has a probe, it will likely utilize that as well.
So long as you don't push them all at the same time or hammer on them, it is good to experiment with the buttons. I myself miss the old dial controlled microwaves:)
Regards, Farmerbear at FixYa.com
Electronic controls are easy to operate and offer one-touch operation
1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
5 sensor cooking options automatically monitor cooking progress and
adjust time and temperature for delicious results; sensor options
include beverage, reheat, popcorn, potatoes and vegetables
Auto and time defrost functions make it easy to thaw food quickly
Express cook control with 1-6 minute intervals for cooking or reheating leftovers
Add 30 seconds option
12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
Clock and countdown timer allow you to conveniently coordinate meal
times; reminder signals let you know when cooking is complete
Black finish adds a touch of style to your kitchen
try{
var divArr = document.getElementsByTagName('div');
var rpDiv = document.getElementById('tabbed-overview');
var spDiv = document.getElementById('saleprice');
var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv);
if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); }
}catch(e){}1150 WATTS
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
there is a relay on front panel this sends voltage to mwave needs to be replaced or dryjointed open front panel and check for little boxes on front panel those are relays
