Question about Palm TX Handheld
Zire 72 Molex ribbon cable
I need a new cable and haven't had any luck obtaining it from Molex or Palm.
Where can I get a molex ribbon cable for my zire 72?
  • 3 Answers
TRY THE FOLLOWING WEB SITE
http:www.thepocketsolution.com/PSI-44850/Tungsten.html
Posted on Oct 02, 2008
Palm zire 72 will not syn with pc running win 8.1
You find a fix to that problem, and the (Palm) world will beat a path to your door. HP, Palm's new owner, has attempted a fix for Win7, but Win8/8.1 may become the impossible hurdle.
Mar 30, 2014 | Palm Zire 71 Handheld
Dash lights stop working fuse is good
You will have to pull the front bezel above the steering column off and below the steering column, you
will need a torx set, and a 1/4 inch socket set. make sure one side of your battery power is disconnected. the bezel is attached to a molex
via a ribbon cable, be careful when pulling it out of the molex, grab the ribbon as close to the molex
as possible, you can rock it side to side to free it. you will see that the back of the bezel has many small
lights, all these lights are wired in series, what that means is that if one goes out, they all go out, you
can pull them out one at a time, check them with an ohm meter, set your meter to check resistance,
you should read a closed circuit if the bulb is good. my recommendation is to replace all of them
and save yourself any future headaches. this way you know they are all good. p.s keep track of their
locations, because sometimes not all the slots are use. good luck!
Feb 20, 2011 | 1993 Chevrolet K1500
How can i install my palm up to the computer without the software? where can i find it?
Hello, Rosilin.
No problem. Here's the link for your Zire 72. You just need to choose Windows or Mac and download and install the Hotsync Manager software.
http://kb.palm.com/wps/portal/kb/na/zire/72/unlocked/downloads/page_en.html
Hope this helps.
Jan 05, 2010 | Palm Zire 72 Handheld
How to insert a sim card into my Palm Zire 72
No sim card in the Zire 72. On-board memory on the motherboard only to store records not directed to or on expansion memory card.
Zire 72 battery changeout not designed to be user serviceable. Undertake at your peril (unless you are very steady handed, patient, and very very careful). The 72 is probably the most difficult of the Palms to change batteries. Go to: http://forum.brighthand.com
Navigate to the Zire 72 section and read the posts. There are even detailed photos and uTube movies that deal with changing the battery. I have used their forum for years. Lots of help there.
May 30, 2009 | Palm Zire 72 Handheld
No power and i cannot charge my palmone zire 72
Unfortunately Palm battery has a life cycle which is about 500 recharge after that will not charge well and will be end of its life. However you can replace the battery. Which can be obtained easily a 3.7V 700mA and above will work fine just make sure size will match
May 20, 2009 | Palm Zire 72 Special Edition Handheld
My PalmOne Zire 72 no longer re-charges. I think it might be the connection on the hand held unit itself. Does anybody here know where can I send it to have the repair done?
Its most likely caused by battery's life cycle has come to end. You may obtain a 3.7V OEM battery with same size of your original battery at least 700mA. you may replace if you wish to DIY or ask local repair tech assistance.
May 04, 2009 | Palm Zire 72 Handheld
Ready to change battery in zire 72s
Here is a video I found on replacing the Zire 72 battery. I hope this
helps.
Mar 26, 2009 | Palm Zire 72 Handheld
ZIRE 72 CAMERA
I changed the battery in my PDA recently and encountered the same problem. The fix for me was in the camera circuit board cable, the one at the top. For some reason, there is no actual plug for cable to go in, so I thought it just rested as is. The cable must actuly be pulled gently back towards the top of the PDA and then aligned with the contact pins from the circuit board. Again, it doesn't actually plug in to anything, but just rests against the pin connector. Be careful reassembling, because the ribbon cable can pop out of place easily (it essentially becomes "spring loaded" when put in place). Hope this works for you.
Mar 13, 2008 | Palm Zire 72 Handheld
No mail app/client found on my Palm Zire 72 :(
Pop the CD in again and look under the CD Extras.
Sep 12, 2005 | Palm Zire 72 Handheld
Palm TX Handheld Logo
69 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
