Installed new motherboard (ALiveNF7g-FullHD R3.0) trying to install ASRock(R)Serial ATA Driver diskette generator Version 1.03 but once inserted a blank formatted diskette into floppy drive A it goes to 100% complete it then says ''sector not found can not redirect input from file.'' Once this message appeared the system reboots. I have tried this with many different floppy disks but all have the same result. I need to install this driver before i can boot onto O.S.
guide2u
  • 461 Answers
SOURCE: Serial ATA controller
try fat 32
Posted on Sep 05, 2007
usmcrave99
  • 69 Answers
SOURCE: misplaced rompaq diskette
You probably need to change the boot order in the bios to make the computer boot from the cd rom before any local hard drives.
F2 is usually used to access the BIOS, you have to press it immeadiately upon seeing the first screen, which usually displays the name of the manufacturer, and from there you have to find the section to change the boot order.
Posted on Dec 08, 2008
MGCO420
  • 11 Answers
SOURCE: floppy diskette seek failure
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Posted on Jan 14, 2009
20YrsCompExp
  • 227 Answers
SOURCE: Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Posted on Apr 16, 2009
romsky79
  • 822 Answers
SOURCE: How to install Adaptec SCSI driver when installing XP -Z Pro 6223
you have to use sata xp cd to intall that driver no need floppy disk.
Posted on Aug 19, 2009
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample below:
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will be furnished after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Serial ATA cables. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the motherboard.
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar if possible.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    May 08, 2014 | ASUS K8V-MX Motherboard
    I have an Asrock Alive NF7G-FullHD motherboard. The pci-e slot is not working what maybe the problem of these boards? I have 4pieces of these boards all have the same problem. Thanks for your input.
    You have to change the BIOS settings for the Primary Graphics Adapter. Restart the system and go to BIOS Setting and Change the Primary Graphics Adaptor to [PCI Express]
    (This item will switch the PCI Bus scanning order while searching for video card. It allows you to select the type of Primary VGA in case of multiple video controllers.)
    The default value of this feature is [PCI]. Configuration options:
    [PCI], [Onboard] and [PCI Express].
    Asrock Alive NF7G-FullHD User Manual
    Please refer to Page 46 of the above Manual
    Hope it helps! Good Luck!
    CreativeTECH
    Feb 22, 2011 | Asrock ALiveNF7G-HD720P M/board, nVidia...
    Where can i download Asrock ALiveNF7G-HD720P m/board driver for free
    http://www.asrock.com/MB/download.asp?Model=ALiveNF7G-HD720p%20R5.0
    Oct 04, 2010 | Asrock ALiveNF7G-HD720P M/board, nVidia...
    Hard disk not detecting
    It is very likely that your motherboard is not capable of handling large HDDs. Too bad, friend. Use a smaller one, or may be two of them.
    Sep 08, 2009 | Asrock K8Upgrade-VM800 Motherboard
    Mother board Drivers
    asrock ALiveNF7G-fullhd rev. G7A1.01 can't find mother driver with this version
    Apr 15, 2009 | Computers & Internet
    1 TB HD of Samsng is not recognized
    some motherboards and processors are compatiable with certain hd's only. Here is a list:
    Pentium: 2GB through 5GB
    Pentium 2:5GB through 20GB
    Pentium 3: 20GB through 40GB
    Pentium 4: 40GB through 500GB
    Pentium D: 40GB through 1TB
    Celeron: 2GB through 500GB
    All AMD's: 300MB to whatever.
    so, that's probably your problem. I suggest
    Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
    Computers & Internet Logo
    138 people viewed this question
    David Payne
    David Payne
