Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Maytag Ensignia Washer-all lights blink
I cleaned the white plastic debris filter/trap in the cold water supply hose and reconnected. Now when i try to run a wash cycle, the washer begins but in about 10 seconds stops and all indicator lights blink on and off.
jimsizemore@hotmail.com
  • amychristine Nov 20, 2008
    Mine does the exact same thing, but it started after it got off balance one time.
SOURCE: Maytag Ensignia Washer Leaks
I have the same problem. Just took mine apart here is where you can see how to get the front panel off. If I figure out the problem I'll post an update.
Panel opening:
http://www.applianceaid.com/atlantis.html
Posted on Feb 28, 2008
kaienana
  • 10 Answers
SOURCE: Maytag Ensignia Oversize Cap Plus Washer stopped working in mid cycle
Check the water level control, it could be stuck or faulty.
Posted on Jul 07, 2008
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
  • 464 Answers
SOURCE: Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Posted on Oct 11, 2009
heatman101
  • 43501 Answers
SOURCE: my washer just quit letting water run into it it
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Oct 20, 2010
What is hot water and what is cold water hook up on back of washer?
The hot water inlet is normally in some way marked red, either with a red plastic 'washer' or by red paint. The cold one is either white or left blank ;-0)
Now a bit of value adding!
You will probably find that each inlet 'port' has a fine filter inside it . If you start suffering from water inlet problems like 'slow fill' turn the water supplies off, remove both hoses from the washer then clean these fine filters before replacing everything.
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
The cold water just trickles into the machine, the hot water fills fine. I removed the hose from the wall and cleaned that filter. Is there another filter I can clean out?
Hello klj... Unscrew the cold hose from both ends and run a wire through the entire length to remove any blockage anywhere. Also check the connection locations looking for calcification of some kind. If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve. Joe
Thanks for choosing Fixya!
Dec 06, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
The cold water just started to barely trickle on all cycles .... i checked the line going in to see if it had one of those mesh filters and it does not. how do i troubleshoot this?
You also want to check at the back of the machine where the hose connects. Some machines have a small screen inside the threaded portion of the valve that may trap debris. Be sure to check both ends of your cold water hose for screens also and be sure to run the cold water full blast through the hose directly into the washer before re-installing the screen (if there is one) to lift and eject any other heavy particles that may be floating around in the cold water supply. When doing this flush out method make sure the pressure is good and that you don't have a potential plumbing issue causing your troubles.
If none of these suggestions fit your next option is to replace the cold water valve.
Jun 16, 2010 | Maytag PAV2300 Top Load Washer
Hot water will not shut off.
HI. This is usually the fault of a failed water valve assembly. This device should be inspected properly for damage. it is possible that you will need to replace the entire valve assembly. To isolate the issue, follow the procedure I have provided, below.
WATER INLET VALVE INSPECTION PROCEDURE:
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
May 02, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Pre select cycle times are getting longer
try cleaning the hose screens and the screens in the water valve. tuen off the water supply and remove the hoses from the back of the machine as well as the water supply. check for sediment or other debris and replace the screens as needed and reconnect.
Jun 09, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
