Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP Hello - My Dell 2001FP woks fine in anolog mode but the minute connect it via DVI, the power light goes from green to amber and there's no picture. I occassionally get the message that the monitor is in sleep mode, move the mouse or pree any key, but nothing ever happens. What should I do?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
You rmonitor is likely fine, and the culprit is most probably your PC, specifically the graphics card. We won't rule out the monitor, however, until learning the specifics regarding your equipment - PC, graphics card, motherboard, and so forth, please.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 14, 2008
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
With Windows XP and Dell Latitude docking station, Dell 2001fp set to DVI, goes to Power Save mode and no display. It works fine with VGA input. It had been working fine for ~2 years.
Update Bios & Video Driver Also right click on my computer,go to properties,go under hardware,you can see hardware profiles,delete the dock profile (while the system is off the dock) & then dock & restart
Jan 08, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a dell 2001fp. it is locked and can not access it to change it to vga, however it has a fine picture on dvi, any ideas
When you change to VGA, you have to change cables to a D-SUB cable. If you want to use S-VIdeo, you have to use an S-Video cable. You could actually have four different devices using the four different cables connected to the monitor one time, and change which one you are looking at by suing the button on the front panel to select the appropriate input.
Oct 11, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Monitor goes to power save mode on startup
Sounds like a bad video card (if embeded "built in") then you need a new mother board
Dec 09, 2008 | Belkin (F6C800-UNV-PL) UPS System
Dell Monitor 2001FP Blank Screen
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
182 people viewed this question
Alun Cox
