Question about Rangemaster 110 (Gas) Kitchen Range
Clock/Timer On the clock/timer a key symbol has appeared and the oven will now not work, any solutions?
  • kaz42 Sep 14, 2008
    Have got the manual but the timer was replaced recently and is a different model than in the manual, and I didn't get any new instructions when it was repaired.
    Scholar:
  • 83 Answers
Is there a childlock feature that has been accidently turned on?
Have you got your manual for the appliance?
Such a feature would prove worthy around young and curious children.
Posted on Sep 14, 2008
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Rangemaster 110 (Gas) Kitchen Range Logo
139 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
