Question about Apple iPhone Smartphone
How do i open the iphone to put the sim card in
    Sergeant:
  • 196 Answers
On the top of the iphone right next to the ear-phone socket is a little hole.. and next to that of course is the drawer for the sim-card. Simply insert a pin/paper clip or similar into that hole and the drawer will pop open.. some people say they found a tool in the phones box for the job but I know nobody here in England that ever had one in the box... a pin dose it fine anyway
Posted on Sep 14, 2008
Need to open my iphone to put in the sim card
Use a paper clip, bent open. Stick the end in the tiny hole at the top of the phone where the sim card slot is. Tilt the paper clip at a slight angle and pull up to remove the sim card holder and sim card if installed.
Dec 10, 2011 | Apple iPhone 3G
Tip
How to replace iPhone SIM card
The only thing that you must have is a SIM eject tool or simply a straightened paper clip or any pin-like object hard enough to push-open the SIM tray. BTW, this SIM eject tool came with the box when you bought your iPhone.
Here are the steps:
First, refer to the image below to locate the SIM card tray. To pull it out, you need to insert the SIM eject tool (or the paper clip) on the tiny hole on the top of the iPhone 3G or on the right-side of the iPhone 4. Push until the tray pops out.
NOTE: The tiny hole found on the top of the iPhone 4 is not for the SIM card tray, it is a microprhone. Please do not insert any thing in there.
Once the tray pops out, pull it out completely and replace the SIM with any SIM you want.
When you're putting it back make sure that the SIM carrier logo is facing the front of the iPhone. Don't force it if it get stuck, just pull it out again, and gently put it back.
Here's an image for your reference:
Please read my other tips:
JAILBREAK
http://www.fixya.com/support/r5452955-jailbreak_all_idevices_iphone_4_3gs
UNLOCK
http://www.fixya.com/support/r5537989-unlock_iphone_4_3gs_3g_or_older_ios
on May 06, 2010 | Apple iPhone 3G
IPhone 4s is coming up with invalid sim or no service
I just had the same problem. I used a paperclip to open and remove the sim card tray. I blew on the card and the opening to clear off any dust. After re-inserting the card, the device said "No SIM" for a moment then registered and regained service. I hope it helps!10_22_2013_4_27_57_pm.jpg
Oct 31, 2011 | Cell Phones
My iphone cannot detect sim card after fall down, no service at all although I took out n put in my sim card for many times, help~
You have damaged your iPhone or your SIM card.
If you have another phone, you could test your SIM card by putting it into it. If it works, then it's likely an issue with your iPhone. If you can borrow a friend's SIM card, you can try putting that in your iPhone. If it works then you know you have a problem with your SIM card.
In either case, you should talk to your service provider to see if they can repair it for you.
Mar 28, 2011 | Computers & Internet
How do you open the iphone to insert SIM card?
You can not open the iphone to insert a SIM card. There is a slot at the bottom of the iPhone and the SIM card goes in there. When you purchased the phone you should also have recieved a special gadget that you actually push into the bottom of the phone so that you can remove the Sim card. That is the only way to access the SIM card on the iPhone... The actual phone can not be opened..
May 05, 2010 | Apple iPhone 3G
Where to insert sim card in iphone 3gs
At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
Put your sim card in the tray and put back in the iPhone
Dec 25, 2009 | Apple iPhone Smartphone
How to change the simcard of my apple 3g iphone?
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door.
1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button.
The paper clip is a valuable tech tool.
2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Apple iPhone 3G
Sim card
Open it and put it in.
Mar 01, 2008 | Apple iPhone Smartphone
2 Problems..Sim Card Problems
Well, first off, an iPhone won't work at all with a T-Mobile SIM card. American iPhones are locked to AT&T's network -- only AT&T SIM cards will work in them.
As far as activating it with AT&T, make sure that the iPhone isn't connected to the computer while you install iTunes. Once iTunes is installed, connect the iPhone to the computer and iTunes should launch automatically and begin the activation wizard. Just follow the instructions on the screen and answer the questions.
Dec 05, 2007 | Computers & Internet
Apple iPhone Smartphone Logo
51 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
