Question about Remington Titanium Series Rechargeable Shaver
Reassembling a remington r3 titanium series razor
I need help in reassembling the above razor. Have lost the user manual and blades not slotting in where i thought that they should.
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Remington HKVAC-2000 Electric Shaver
Hi beebee73
If you are referring to the hkvac2000, it is a clipperstyle shaver, where the blades, because of the cutting action, do not generally need to be replaced. I have checked on the Remington website, and they do not sell any spare part blades for this model. To se what all comes with the shaver... comb sizes etc, check out the user manual for the device here
Hope this helps you. If you need me to do some more research, just ask:) Thanks for using FixYa, a FixYa rating would be great for my efforts to get this information for you. Cheers
regards
robotek
Posted on May 08, 2008
brector3
  • 1565 Answers
SOURCE: Dear Sirs, Hope you can help, I purchased a
I suggest that you use Remington pre-shave stick. It helps with this problem. It can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-sp5-face-saver-powder-stick-p-194.html
Posted on Jun 04, 2010
brector3
  • 1565 Answers
SOURCE: i have a Remington 650s
The faucet emblem means that you can clean the shaver head by rinsing it under running tap water. The terminology is 'washable'. It does not mean that it is 'wet and dry' for use in the shower. Such extreme exposure to water on this model may damage the unit
Posted on Nov 27, 2010
brector3
  • 1565 Answers
SOURCE: Anyone know HOW to change
It is doubtful that the cord is the problem unless there is visable damage to the cord. Most likely, the batteries are dead. You will find the correct replacement battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change them, take off the back cover by removing the screws. Inside you will see the two batteries. There may be some black tape on the ends. If so remove the tape so that you can get to the tabs on the batteries. Unsolder the old batteries from the wires and solder in the new batteries
If you are not equipped to do this yourself, shaveroutlet.com can do it for you. See link below for information and ordering
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Dec 05, 2010
woodchuck789
  • 4059 Answers
SOURCE: The rechargeable battery on my
E Bay is a good place to find razor parts. They have new parts and you don't have to bid on them since they have a Buy It Now price.
Posted on Dec 09, 2010
1@live.comhow to use a remington titanium r 9500 electric razor
try looking in the manual for the steps on how to use remington titanium r 9500 electric razor..
Apr 28, 2011 | Remington Health & Beauty
How often should i change razor blades
Remington suggests changing the blades every 12 months on model R5103. If replacements are needed, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Mar 02, 2011 | Remington R5130
My smart system razor no longer charges. Have to use it whilst plugged in. What could be the problem with the charger?
Hi, I had this same problem and did some research. In the beginning I was told it HAD to be sent back to Remington for the service. As with all electronics, I end up fixing them myself. I bought the replacement batteries from electricshaverstore.com for $15.00 and now it works great. Good Luck and I hope this helps!
* Make sure you get the R9000 Series Battery Replacement.
Dec 14, 2010 | Remington Titanium SmartSystem R-9500...
What is the procedure for replacing the batteries in the Remington Titanium R 9500?
There are three screws on the back of the shaver to be removed. One is easy to see. The second is visable when you extend the trimmer. The third is hard to get to and the trimmer must be disjointed at the top to get to it. Once all three screws are removed, you can remove the back cover. There are two batteries. To remove them you will need to unsnap and remove the long metal clip and then unsolder the wires connected to the batteries. There may also be a gummy substance holding a wire to the side of one of the batteries. You will need to use a razor blade to seperate it off along the side of the battery. Once the old batteries are removed, you can solder in new batteries and ten reassemble the shaver.
You will find batteries at shaveroutlet.com. See link below. You will need to order two.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
If you are unable to do this repair yourself, shaveroutlet.com can do it for you. See link below.
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Mar 15, 2010 | Remington Titanium SmartSystem R-9500...
Cutter blades and cam repeatedly jams requiring dismantling and reassembling of the blade and cam assembly.
Sorry to have to tell you this but Remington has gone bankrupt. The unit only had a one year warranty on them and when they broke, a new unit was sent to replace the broke one. It was considered a throw away unit.
Sorry for the news but that is part of being in a "disposable" society.
Good Day.
Oct 24, 2009 | Remington At3017b Hedge Wizard
Hi beebee73
regards
robotek
May 08, 2008 | Remington Microflex R-860 Electric Shaver
Remington Titanium Series Rechargeable Shaver Logo
94 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Robert McClure
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
