Have new Logitech X-540 speakers and surround sound is not working. Rear speakers are not working. Only recognizing the line out. I have onboard 5.1 sound with my PC
    Problem Solver:
  • 8 Answers
Do you have a 5.1 speaker??? if you do have try to install it in different channel if you have a 5.1 sound card you should have 6 channel for the mic , head phone , tweeter bass and surround ... if you only have 2.1 speaker try to put the speaker jack to different channel and check if it work... or try to reinstall the driver for your sound card...
tnx for using fixya
evanskie
Posted on Sep 14, 2008
I have a new dell inspiron. I just purchased Logitech x-540 surround sound speaker system. The right front, left front, and center speakers don't work. Everything seems to be hooked up right. Any ideas. Is...
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
Feb 21, 2010 | Logitech X-540 Multimedia Surround Sound...
I have the logitech x-540 5.1 speaker system, do i need an adapter to plug in to my macbook and iPod? so I am able to have hear all 5 speakers together?
Yes, you do, the adapter has 1 green end, which gets plugged into your computer and then the other end has 3 connectors, green, yellow, and black, which then goes into one thick cable. I have the set up right now.
Dec 03, 2009 | Logitech X-540 Multimedia Surround Sound...
Logitech X-540 limited sound
why dont you have them all hooked up? I have the same speakers but I the model that only has 2 speakers. Try pluging your audio cable in the front where you would plug head phones in. Assuming that this is a desktop.
Jul 24, 2009 | Logitech X-540 Computer Speakers
How to connect Logitech X-540 to a laptop
buy a usb 2.0 type soundcard because your laptop does not support 5.1 surround speaker here is the link that will solve your problem http://www.amazon.com/Zalman-ZM-RSSC-External-Sound-Card/dp/B0001OZ2K8
Feb 10, 2009 | Logitech X-540 Computer Speakers
Logitech X-540 Configuration Confusion
Your speaker system is designed for the 5.1 surround. *********** board manual shows you which wire goes to where.
Dec 13, 2008 | Logitech X-540 Computer Speakers
Rear and Centre speakers not working
The system comes with l remote which provides controls for "Power", "Master Volume", "Bass (Subwoofer) Volume" and "Matrix Mode" . Matrix mode allows you to spread stereo sound to all speakers where your sound card may not have the ability to do so.
I find that the "Stereo Surround" setting works best as opposed to the recommended "CMSS" setting
Oct 22, 2008 | Logitech X-540 Multimedia Surround Sound...
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Logitech x-530 5.1
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting. Go here to get an operations manual for this setup. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=d*11Q7xi&p_accessibility=0&p_tbl=9&p_id=2924&p_created=1126107772&p_olh=0 Good Luck
Mar 22, 2007 | Logitech X-530 Computer Speakers
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
