Question about Maytag Neptune MAH5500B Front Load Washer
Cannot unlock door
I was running the washer last night, and mid cycle there was a power failure. The power came back on quickly, I went to the washer, which was flashing PF. I touched the start button and it resumed it's cycle. This morning I tried to open the door and it was locked. I touched the buttons on the displey and they do not light up, as if there is no power going to the display. I unplugged the machine, plugged it back in, still nothing will light up.
Is there a fuse inside that needs replacing? How can I get the door open to get the wet clothes out?
Thank you
  • 6,487 Answers
This can be a bad/loose connection at either the Logic Board, Relay Board, or at one of the 3 main power connection terminals on the back of the unit is the problem..if you have knowledge about this type of machine you can check it but if not better ask for someone who knows about this machine..
Hope that helps...........
Posted on Sep 14, 2008
  • Maytag Master
  • 19,396 Answers
Try first putting the control on 0 , then unplugging power cord for ten minutes, then plugging it bac.
If this does not work try restarting the cycle at any point and leave the cycle to complete, then you try openoing the door.
  • Ginko
    Ginko Sep 14, 2008
    Regarding the fail, PF error just mean power failure.
    The problem is not a matter of fuses, fuse is ok.
    The problem is that cycle did not finished and there is water still inside the machine.
    If the unplugging power cord did not fix the problem, then you need to restart and complete the cycle, so that the machine can drain the water inside, then you should be able to open the door.
    If cycle does not restart try also keeping pressed start button for ten seconds or so, then restart cycle.
    If the door does not open after doing all the above, then the drain pump is stuck, if that happen then you may need to call a technician to take apart the appliance and fix the pump.
  • Ginko
    Ginko Sep 14, 2008
    Good to know that you had a bad/loose connection at either the Logic Board, Relay Board, or at one of the 3 main power connection terminals.
    Figure out that I thought it was a completely different problem, I understood the door was not opening!
    Iwill try to read better the question next time, may apologies.
2003 tahoe power windows and door locks stopped working. As well as engine cranks and dies. this all after battery went dead overnight from failure to shut door completely.
Hello Chuck Womble,
Admit it...
DRIVER'S DOOR switch takes the most
abuse on the planet.
(alcohol, true love, regular chaos or old age:
snow + rain + dirt + coffee) = dirty abused switch))
A healthy BATTER would probably feel better after
a DEEP CYCLE discharge/charge...
That BATTERY WAS ALREADY done.
Make sure the NEW BATTERY terminals are
clean & tight...
WD40 the door switch (doubtless the driver door
that was open all night... (with power off)).
If cycling the switch does not bring it back to life
Get a new switch... while they are still plentiful.
Rockauto window switches
2003 CHEVROLET TAHOE 5 3L V8 Power Window Switch RockAuto
Battery terminal washers
Amazon com Road Power 0989 Anti Corrosion Fiber Washers 1 Pack 2 Washers 6...
Carnac the Magnificent
Jul 27, 2017 | 2003 Chevrolet Tahoe
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
Samsung wf317aag stopped mid cycle now machine has no power
First, are you sure there is power to the unit? Check the breakers and post back.
Nov 03, 2012 | Samsung WF317AAG Front Load Washer / Dryer
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Door locked no power
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock. On some machines it maybe be required and sometimes easier to remove the bottom kickplate and access the lock assembly from there
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Oven will not unlock.
There is a little motor at the back of the oven that rotates a shaft that runs all the way to the front of the oven to lock the door. The motor may be shot:
http://www.partselect.com/PartDetail.aspx?Inventory=2342830&SourceCode=4
89 318095949 Motor, latch assy, w/brkt & switch
Apr 04, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
