Question about Dell 966 All-In-One InkJet Printer
Dell 966 all in one
The band behind the cartidges came off as well as the white gear.
  • larry5492000 Nov 07, 2008
    the belt that runs the printer is to lose how do i tighten it
Yes the round white thing connected to the belt is off and i think i have the same problem you did
Posted on Nov 07, 2008
  • 3 Answers
I had this same problem and with some difficulty was able to fix it.(i have moderate experience with taking things apart but i am no expert.) i had to take the printer apart. just pretty much the outside case, nothing really much inside. on the right you will see this black thing connected by a metal rod. the white gear sits on top in that black thing with the band around the gear. on the bottom the black thing is connected by a spring. what happen to me is that black thing is very weak where the spring connects, and all the tension caused it to break. i was actually able to fix that black thing using paperclips. so far its been holding up and i think it should stay. if you want you can email me skradtim@hotmail.com and i might be able to sketch a picture of how it is connected. you may have to shake your printer upside down to recover any pieces. if you have trouble recovering the spring or any metal piece, check on the far right. their is a small speaker and as you probably know the backs are like magnets.
Posted on Sep 20, 2008
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
Model 966
You can buy a copy of the manual here for $10 (includes shipping): White 966 Instruction Manual
or download a copy here:
http://www.singerco.com/uploads/download/861_white-966-x.pdf
Apr 24, 2014 | Other White Sewing Machine Instruction...
Printer is saying cartidge error#1203
If you open your printer up so you can see the cartridge, you'll see a very thin possibly "SEE" through plastic bar just behind the cartridge holder. Sometimes this bar comes out of the slot behind the cartridge (its called an encoder strip) and it will just need put back in or it may just need a wipe over. If that doesn't work you will have to dismantle it and check that the ribbon cable that connects cartridge holder to the board is secure.
Dec 30, 2010 | Dell 966 All-In-One InkJet Printer
Every time I send a fax from my Dell 966, a black stripe appears down the middle. All photocopying/printing is operating normally, its just the fax that won't work! How do I fix this?
its quite possible the area that scans the paper(s) you are sending is dirty.
If the machine is one of those phone/fax/scanner/copier jobs, simply open the top panel, and with a damp cloth, wipe the runners that feed the paper through from left to right or right to left (just make sure any dirt you're wiping goes off to one side)
its also possible that a paper (that white-out was used on) that has been recently faxed, left some white out on the feeders
Aug 16, 2009 | Dell 966 All-In-One InkJet Printer
DELL AIO 966 Carrier belt detached from printer
The belt goes through the back of the ink carrier.
There is a spring somewhere that keeps tension on the belt with the white roller.
The belt itself hooks into the frame of the machine.
Jun 21, 2009 | Dell 966 All-In-One InkJet Printer
Printer carrier stall
I am getting a "Printer Carrier Stall" message and "Check printer for obstruction" message. what can I do to fix it?
Oct 03, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All In One Printer, cable disconnect from wheel
i had this same problem and with some difficulty was able to fix it.(i have moderate experience with taking things apart but i am no expert.) i had to take the printer apart. just pretty much the outside case, nothing really much inside. on the right you will see this black thing connected by a metal rod. the white gear sits on top in that black thing with the band around the gear. on the bottom the black thing is connected by a spring. what happen to me is that black thing is very weak where the spring connects, and all the tension caused it to break. i was actually able to fix that black thing using paperclips. so far its been holding up and i think it should stay. if you want you can email me skradtim@hotmail.com and i might be able to sketch a picture of how it is connected. you may have to shake your printer upside down to recover any pieces. if you have trouble recovering the spring or any metal piece, check on the far right. their is a small speaker and as you probably know the backs are like magnets.
Jul 23, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
63 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
