Question about Denon Audio Players & Recorders
Denon DP52F tonearm tube is turning freely
I have a Denon DP-52F, purchased used, which now (and suddenly) has a freely turning tonearm tube, which of course completely prohibits play. Is something I can easily remedy, or do I need to bring it into a repair shop? What would cause this "sudden release" of a normally static arm tube. Did something let go, loosen or strip? Thanks very much.
  • 4 more comments
  • Musicseller Sep 14, 2008
    It has absolutely nothing to do with the motor. It is a disconnect of some sort withing the servo assembly, where the tube connects to the "unseen".
    To try to make this more understandable, the arm turns 360 degrees. In other words I cannot ever know if the cartridge is going to be facing down, sideways or straight up in the air. Somehow it needs to be reanchored within the boot assembly.
    This should be simple; these are generic answers that I'm not accepting. Sorry...
    The tonearm wires are not the problem. They could be fully intact or nonexistant, as the tube ends shortly after it enters the boot, at which point they are on their own. Plus, I have conductivity throughout.
    What on God's good earth has this last post got to do with anything I've mentioned?
    Now, that makes sense. Any idea how I might do that? Thanks....
    Genius:
  • 1,665 Answers
You must raise top cover to have acces to arm support shaft and tighten holding nut.
Posted on Sep 14, 2008
    President:
  • 1,952 Answers
Use the audio technica AT155LC cartridge or as close as you can get, thoroughly clean the vinyl with a clean soft cloth and windex(yes, standard windex)cycle the record once stylus down volume off, look at the stylus tip -see any dirt on the point yes- cut down a sable touch-up brush leave about 1/4 inch above the metal crimp..this will stiffen the bristles ...be careful not to push too hard ...after a while you'll figure it out ..if its real sticky hard to remove or you can't get all of it off then use a little alcohol...after that you won't believe the difference.....df ..about the wires...they come pre-made in a set (small) you replace them color coded one at a time...>before you mount the stylus...df
    Genius:
  • 3,422 Answers
HI,
One common problem for turntables is frayed or broken tonearm wire. The tonearm wires run the length of the entire arm’s interior, pass through the metal plinth and connect to a wiring post that is screwed onto the inside of the wooden base. The point where the wires pass through the plinth is where damage is most likely, and it comes from decades of rubbing against the edge of the hole in the plinth.
  • Priya darshan Sep 14, 2008
    You can try to fix that yourself,if this is not under warranty.If it is under warranty do not even try to do this because it will void the warranty.Now please click on the below link.It is not exactly for your mode,but it will help you troubleshoot the issue.
    http://www.vinylnirvana.com/ar_rewire.sh...
    If you are satisfied with my solution then please don't forget to accept it.
  • 2,071 Answers
Just click below for operating manual;
DENON DP-51F and DP-52F TT OPERATING INSTRUCTIONS en venta en eBay ...
Hope it may help you;
Regards,
VOTIT
    Genius:
  • 1,268 Answers
Better take it to a repair shop. There might be loose gears which need to be tighten or replace.
    Genius:
  • 1,847 Answers
The issue seem to be with the motor.
Denon DP 300F turns extremely slowly.
If like what you say the deck is brand new you should contact the service center. They will attend to the matter free of charge. Web address follows:
http://denon.custhelp.com/
Dec 13, 2014 | Denon DP-300F Turntable
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
Need replacement Sgnet cartridge/stylus for Denon DP52F , old was a TK9LC
You can use any cartridge you want as long as it will fit the headshell.
Feb 10, 2014 | Denon Audio Players & Recorders
Running VERY slowly
The thing to do is to check the belt first, then look at things like is there a build up of grease dirt anywhere. Clean up the platter make certain no grease or dirt is the works causing it to slow down.
See also that the motor that drives the belt can turn freely and very easy by hand.
Jan 25, 2014 | Denon DP-300F Turntable
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
Denon DP- 60L Tonearm bearings are loose, How should I adjust them..?
They can not be adjusted, Turn table has obvisily been abuse,Just buy a different one, End don,t abuse it,
Nov 02, 2012 | Denon Audio Players & Recorders
I have a denon DP-7F direct table (1989)ust wondering about the point of the arm the head of the cartridge housing is very close to the record any way to get that adjusted higher?
If the tonearm balance and tracking force for your cartridge are adjusted correctly, ignore it.
Register and download the manual for free at vinylengine.com
http://www.vinylengine.com/library/denon/dp-7f.shtml
Eeeww, page 8 says the counterweight snaps on and the tracking force is factory set. Any self-repecting turntable should have precise manual balance and tracking adjustments. Or your counterweight is not on? Either way, I'd look seriously at getting the stylus checked for excessive wear if it's tracking too heavily. The manual says 500 hours of normal use. You'll be carving up your recordings.
Maybe post the question to the guys at Vinylengine
Apr 30, 2011 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Turntable speed erratic
It is likely that grease has hardened and as the gears rotate that grease is interfering with normal operation. Take the unit apart and have a look at the drive mechanism, if there is something in the gears you should be able to see it.
Jan 01, 2009 | Denon DP-47F Turntable
516 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
