Question about Lowrance GPS
Is online training available for the LMS-520c?
  • 13,433 Answers
Haven't found any. But the manual covers about everything
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS525CDF-520C_0151-461_120706.pdf
252 pages, you should be able to find answers to any problem you might have with the unit from there.
Posted on Sep 14, 2008
Lowrance X135 blows in-line fuse and won't power up? How to troubleshoot
First, follow the wire from the fuse to the unit. It may be pinched or cut somewhere between those two points. Seems simple, but this happens often. If the wires look ok, You could also try a fuse one size bigger. If it blows that fuse, then the problem is in the unit, and you will have to sent it out for repair.
Apr 10, 2014 | Lowrance Lms 520c 5" Screen Color External...
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Flashing screen
two things can be taking place 1 you have a bad key pad 2 you have a bad transducer(short in wire )
Oct 22, 2013 | Lowrance Lms 520c 5" Screen Color External...
I have a lowrance LMS 520c and I never pick up any fish. it does show the bottom
read the book that came with it you got to understand how it works and know how to set your unit before you can understand how it works and what you need to do to make it work and to get to what settings you want ..a fish finder is like a computer you got to program it to your likings .. I have a hd 10 structure scan on mine .. .now that's a nightmare to set but the book tells you everything you need to do and how to do it and how to get what your looking for and how to get to it
Jul 28, 2013 | Lowrance Lms 520c 5" Screen Color External...
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
I purchase a lowrance LMS-520C about 18 months ago. The depth gauge cuts in and out. It works for a while then defaults to 3.3 feet while trolling. Can you point me in the right direction to find the...
Quite often those transducers go out. Not 100% sure but would bet money on it. Call Lowrance customer support and see if the offer any more advised but more importantly see if they can replace your current one as a replacement instead of you having to pay full retail price. I purchased a new gps module through customer support and saved $150 off the normal retail price. Best time to call customer service is at 8:15am central time when the lines are turned on!
Feb 28, 2010 | Lowrance Lms 520c 5" Screen Color External...
I have an 1997 540i BMW, and I need to know the price on a disc for a GPS system or where to get one.
I have seen these listed on craigslist from 200 to 400 dollars. I do not know a store that carries them in stock other than the dealer may have it but you will pay threw the nose for it.
Feb 12, 2010 | Lowrance Lms 520c 5" Screen Color External...
Won't power up
Make sure the power is good, and the power connections are clean. Check fuses and connections. You can even get a volt meter, unplug the power cable and test for 12VDC across the two bigger female contacts on the power cable connecter. If you are getting 12VDC, then the LMS-520 is bad. If you are not getting 12VDC, then you have a bad power supply, connection, or cable.
Jul 10, 2009 | Lowrance Lms 520c 5" Screen Color External...
I need CD, or DVD to learn how to use my Lowrance it is modle LMA-332C & LMS-337C DF.
Here you can buy the DVD for $13:
Bennett Training DVD For Lowrance LMS-332C
Here is the user manual:
LMS-332C and LMS-337C DF Owners Manual
Do not forget to rate the solution appropriately.
Many thanks.
Aug 31, 2008 | Office Equipment & Supplies
GPS Logo
118 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
