Question about HP Office Equipment & Supplies
Wont print alignment page. - HP Office Equipment & Supplies
  • masterexpert May 11, 2010
    what is the exact model number of your printer and from where it is not printing the allignment page .from the pc or directly from the printer.
    reply.
    Sergeant:
  • 399 Answers
Go to the printer properties and then click the services option in it and there are three options self test--- cleaning---and allignment--- click allignment.and it will allign.
for any further queries feel free to ask.
thanks
Posted on Sep 18, 2008
My HP PSC 1315 printer/scanner prints the test page every time I turn it on. A 2008 post from littlebluemuffi helped until now, but today it still printed the test pages.
This usually happens if the printer is not aligned properly. When you replace the cartridges, it prints a colorful sheet of paper. You need to place the paper face down on scanner glass and press OK button.
This completes alignment and the printer wont print test page again.
Regards,
Sean
Feb 25, 2013 | HP Office Equipment & Supplies
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My lexmark x2600 keeps telling me i need to realign the cartridge but nothing is really wrong.. wont let me print anything but alignment test pages. How do i fix this
One of the utilities included with the Lexmark software will print a "test" page.
Then, you view the test page, and enter some numbers into the utility.
The utility uses those numbers to (ectronically) align the print-heads.
Dec 18, 2010 | Lexmark X2600 InkJet Printer
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do i print the alghnment page this dam printer wont print with out alighment
You need all the inks full, especially the yellow, and just load paper and allow it to print the alignment page. If black and all colors are working it will pass the alignment, any color missing and it will keep asking for alignment. When it says press enter to align, you can hold enter and press menu and it will quit asking.
Jan 22, 2010 | HP J3680 Officejet All In One Printer
I have the hp d1400 series...it wont print and its telling me i have an alignment problem..it all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
97 people viewed this question
Ben Johnson
