Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WM A54
Hi
how easy / difficult is it to change rear drum brgs on a Hotpoint WM A54 washing machine? I have done this on a Zannusi some years back. I have only just noticed the noise the other half says she has heard it but not as bad as now. There are no leaks visable yet.
Your help is appreciated
    President:
  • 1,462 Answers
About the same level of difficulty as zanussi. however on some wma series the bearings are not available seperately - new drum and tub- so check first
Posted on Sep 14, 2008
What is causing the tub of my top load washer to bang against the back side of the washer while it is in the spin cycle? The washer also vibrates violently.
sounds like the damping system is the problem. The drum may have moved out of place or the damper(s) have become faulty in some manner. I used to have a hotpoint washer that tried to destroy the room it was in by travelling around it after the drum had fallen off its mounts. I bought a new machine, my thinking being that there is no point in taking a risk of having a real disaster if I set it to wash and then go out.
Bosch / zannusi / siemens make good machines
Dec 18, 2015 | Washing Machines
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Drum will not turn
Remove the back panel or look under the unit. There is a belt that goes from the drum to the motor. Either the belt is broken or the motor is no good anymore
May 06, 2010 | Hotpoint First Edition FEW10P Front Load...
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Washing machine makes noise on spin machine type LG
THE SOUND YOUR HEARING IS THE REAR BEARING BETWEEN THE STATOR AND THE DRUM. IF YOU'LL PULL THE BACK PLATE OFF THE WASHER IT'S PROBABLY STARTING TO GET A LITTLE DRIP RIGHT ABOUT NOW TOO. BEARING COSTS AROUND $20.00 OR SO AND IS RELATIVELY EASY TO CHANGE. YHE EASIEST WAY TO MAKE SURE IT'S THE BEARING WITHOUT PULLING IT OUT AWAY FROM THE WALL IS OPEN THE FRONT DOOR AND SEE IF YOU CAN SHAKE THE DRUM UP AND DOWN AND SIDE TO SIDE.
Sep 25, 2009 | LG WM-2277HW Front Load Washer
Knocking on WM63
Hi there!
Yes , you need new dampers for it.
These are easy to fit from the rear. Look at online parts stores under your model, and you should get them delivered within a week.
Check also that any foam bumpers are still stuck on the sides.
Apr 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wma54 washing machine
sorry but not the job i would recommend to anyone not done or watched it done before its about the most difficult job to do on any machine, even though in my 20 years experience this is the easiest machine to do a drum bearing change on, most of the machine has to be stripped down, removing all the front panel / timer panel / door seal and drum front / drifting out the old bearings fitting the new ones and rebuilding the machine, not counting testing for and rectifying any damage the drum has done to the rest of the machine and surrounding parts, good luck if you attempt it, sorry
Sep 24, 2007 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
111 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
