Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffeem maker not working
The lights come on and all the buttons seem to work but the
unit will not get hot are no water flow. And all this came about
after my girlfriend cleaned the unit in the sink witch i think was a bad
idea. Lights stay on for 10 seconds then beep sound comes on and unit shuts down..
Can you help me please?
I a similar problem with my machine. I went 3-4 days without making coffee before i went to take it back. However, when i unplugged it, then plugged it back in, it worked. I didn't figure out why, but i've had to do this twice now. (Hasn't happened in a while.)
Good Luck
Posted on Sep 14, 2008
No heat, no light, has flow and power?
I'm experiencing the samething it's been installed 3 years and christmas day nothing. Please help.
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
When making espresso half way through the pump quits working and display back light blinks with all icons lit. The steamer works fine, it is just when making espresso.
Most likely you will see the problem when doing a single or double espressos and when just producing hot water. All these three functions work based on specific amounts of water. Most likely your flow meter is not working properly. I replaced my flow meter (< $20) and the unit now works fine.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Everything seems to work, door locks, but water won't flow
Check the water solenoid valve, it may have failed. A quick test is to use hot wash rather than cold wash. If the hot water works, then your cold water valve has failed.
Jul 02, 2009 | Kenmore 46462 Front Load Washer
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Apr 10, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
The espresso side of the machine stops pumping water after 5 seconds or so. At the same time the espresso on/off button and main display start blinking. Pushing the hott water/steam button will reset this...
The clue here is that the problem involves the hot wate and the single or double espressos. These three functions require accurate water measurements and they are programmable. It appears that the flow meter is not sending the correct information to the control unit. This could happen if you have blockages or if the flow meter is not working anymore. Most likely you need a new flow meter which only costs about $20 and should not be too difficult to replace. It is located between the water tank and the pump.
Sep 06, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Braun Coffee Maker Type 4093
it sounds like the hole at the bottom of the waqter tank is clogged. the fact that it is hot means the electrical parts are all working.
it should be an easy fix
May 18, 2008 | Braun Aromaster KF 400 Coffee Maker
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
89 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
