How do i check the filter on my hotpoint wf220?
    President:
  • 1,462 Answers
On most hotpoint, the filter is in the hose fro tub to drum. take rear bottom panel off and you will see a large diameter hose from tub to pump. take hose off at tub end and you will find filter inside the hose. carefull, lots of water may come out
Posted on Sep 14, 2008
It says H20
H20 indicates a water supply problem.
Check the water pressure, check for restricted hose/s, check the filters in the inlet valve/s.
Nov 30, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf220
If ther is no filter at the front of washer, then remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose, also remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aqarius mod no wm63x all machine functions fine drum wont spin
check pump/filter/outlet hose is not blocked. if ok check the brushes in the motor.
Oct 21, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Toplight flasing withstart light on hotpoint wf220
check door interlock, may be faulty.
Unplug the washer before checking!
Oct 18, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WF220 won't power on
Could be the plug itself, or door interlock switch, try cutting off plug replacing Interlock cost is around 20GBP.
Oct 21, 2017 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf220 glass door
undo door hinge from cabinet - held with two screws.
the door halves are held togethet with a few screws which undo and the door will split apart so you can replace the glass
Oct 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Washing machine won't spin
check the pressure switch the unit wont spin unless it knows all the water is out of the unit
May 28, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
