Windows xp isnt starting up due to an update problem and has to close can you tell me what the problem is and how to fix it.
    President:
  • 2,961 Answers
You will need to press F8 while the pc is booting up and then a menu option will be available, choose safe mode and then when all the drivers have loaded, choose the administartor account then go to accesories>system tools>system restore, then choose a date to before the last update was installed.
The pc will then reboot and should start as normal without the last update you installed.
Posted on Sep 14, 2008
Windows xp driver updates
No more updates for XP, Microsoft will channel you to upgrade, from their website. A driver update app will tell you what's out of date, but will cost you, remember Bill keeps everything locked close to his wallet.
Apr 04, 2014 | Microsoft Windows XP Home Edition
Am trying to download Office 2010,but the comp. tells me I am not running the XP sp3. How do I fix this ? My comp. does automatic updates.
Manually install the updates by going to the Microsoft Update website. Click start, select all programs, and select Windows update. Allow the updates to download and install. Continue to update until all have been installed. You may have to return to the update page several times before Service Pack 3 can be downloaded and installed.
Jan 26, 2011 | Microsoft Windows XP Professional SP3 Full...
Installed new windows 7 and our Documax A3300 will not print invoices
well thats because the driver is missing or isnt compitable with windows 7,, to verify this right click on computer, click properties and then device manager,, you will notice that there are a few (at least 1) device with a yellow highlight Or unknown Device ,, that means that the driver isnt installed or isnt compatible with windows 7, Now There is a chance it can be fixed and this involves using the windows up date software..
Click Start, then windows Updates, Check for updates and Install All UPDATES INCLUDING Optional Ones.. The drivers are found in the Optional Updates..
Of you can contact the manufacturer of the Matrix Printer and Inquire If They Have A windows 7 or windows Vista Driver (Windows Vista Drivers Do Work in win 7 "Most Of The Time") and you can get it from them,,
I did check their website for it
http://www.amtdatasouth.com/support-1/downloads/drivers/
but did not find a windows 7 driver (Its possible I might have missed it Please feel free to check),, so your best best is the windows Updates Or Contacting Them..
Here is there contact Info
http://www.amtdatasouth.com/contact-us/
Oct 13, 2010 | AMT Datasouth Documax A3300 Matrix Printer
I get an error when I'm closing Quickbooks Simple Start, The instruction at "0x56461f49" referenced memory at "0x036c4360". The memory could not be "read". Do you know what this means and how to fix it?
Assuming you have Windows XP, please follow these steps:
1. update QB . To update QB,launch Quickbooks and then go to Help>Update QuickBooks. In the windows, click UPDATE NOW.
2. Then go to Start>Control Panel>Add/Remove Programs. Then check mark SHOW UPDATES.
Then find Microsoft .NET framework 2.0 SP1 or SP2. Find update KB976576 or KB576976 and remove it.
3. Restart your computer and then launch and close QB.
ISSUE WILL GET FIXED
In any situation, this issue will never ever effect your QB data file.
If issue remains, reply with QB version and Windows Version?
Jul 10, 2010 | Intuit QuickBooks Simple Start Edition...
I purchased A HCL branded Windows XP Home edition with SP1 during the year 2004. Till now I have not used much. Due to development in software the latest version of antivirus could not be loaded. Hence...
First I'd try booting the PC, as its booting press the F8 key several times. This, with luck, will offer several boot options. Choose Safe mode. (A stripped out version of windows)
Assuming it boots into safe mode, Click on start - all programmes - Accessories - System Tools - System restore.
Restore to a date prior to the SP2 installation.
If all that works, update by going through the windows update software - Start - All Programmes - Windows update.
That will update your o's to SP3.
Failing that, without a copy of windows you're a bit stuck.
However, if you are stuck and don't want to pay again for an operating system, you could download and install "Ubuntu" for free. Its a linux based operating system. Just Google Ubuntu, all instructions are on the web page.
Jun 28, 2010 | Microsoft Windows XP Home Edition
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Mine isnt telling me where to turn at all
make sure the gps in not muted. check the mute on and the sound turned up on the map screen and also check the sound in the options/system/ sound, if they are both ok and the try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already. READ UPDATE INFO BEFORE UPDATING,VERY IMPORTANT
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB takes atleast 30 - 60 minutes depending on your system.
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Jul 30, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Exactly the same
is this XP or Vista ? turn off User Access Control if Vista, do the update and then turn it back on, the problem sounds like a permission problem. or if you have a exe , riught button click the exe select Run as Administrator also works on XP.
Jun 12, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Can't find clip in my computer
This is and excerpt from "EphMusicFan" on the Real player forum. Original link is also below.
" The following steps finally fixed everything for me. While it may seem long, it only takes about 15 minutes and should fix everything.
If you run windows XP don't have Windows Media Player 11 installed, download and install it here,
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
Run Windows Update, and install all high priority and optional updates related to Windows Media Player or device synchronization.
On XP, the updates include:
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows Media Player 11 for Windows XP (KB939683)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Open Rhapsody
From 'My Account' menu select de-authorize computer
Close Rhapsody
To delete the mcs.rma file:
1. Close RealPlayer/Rhapsody
2. Click the Windows Start button. Then click Run.
3. Type %windir%\system32\ and click OK.
4. Find the mcs.rma file.
5. Right-click mcs.rma and select Delete.
6. Close the window.
To delete the basi3260.dll file:
1. Open the My Computer icon on your desktop.
2. Open the C: drive (usually Local Disk (C:\)).
3. Open the Program Files folder.
4. Open the Common Files folder.
5. Open the Real folder.
6. Open the Plugins folder.
7. Find the basi3260.dll file.
8. Right-click basi3260.dll and select Delete.
9. Close the window.
10. Restart your computer.
on sansa Clip itself, disconnected from computer, go to settings, then choose format
Make sure Rhapsody, Windows Media Player, and all other media programs are closed
download firmware
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=2946 (make sure you get 'Americas' firmware version)
unzip firmware file
connect to computer
drag firmware file onto sansa Clip icon in Windows explorer
wait to finish all copying (Sansa Clip screen will say connected, not writing or reading)
disconect
firmware updates on device, then it shuts off automatically
turn it back on
reformat from device (settings menu, format)
put in msc (under USB mode on settings menu)
reconect
open sansa Clip E:/ in Windows explorer, delete all files (should be 6-8 folders and files in top level directory of Clip)
reformat from windows explorer (right click, format, (FAT file system, NOT FAT32))
disconect
put in mtp (under USB mode on settings menu)
Open Rhapsody
It will run through quick setup again, due to files deleted before.
'Reathorize Computer' (under 'My Account' menu)
"Update Track Licenses' (same menu)
connect to computer
wait for Rhapsody to fully load clip (may take 30 seconds)
reformat from rhapsody (right click on sansa clip icon in rhapsody, select reformat)
hold down control and shift buttons at same time, right click on sansa clip icon in Rhapsody, select 'reset secure clock'
right click on sansa clip icon in rhapsody, select authorize device
wait while sansa clip updates (wait for screen of device to say 'connected' for a while, rather than writing or reading)
disconect
reconnect
wait a while updates finish
disconect
verify acount, and dates on device, under setting menu, account
should say renewed (with today's date) expires a date 30 days later.
download one new track from rhapsody you never have downloaded before
reconect
transfer that one track to clip
wait for all updates to finish
disconect
verify account, dates on device, check that the track plays properly"
Hope that helps.
http://real.lithium.com/real/board/message?board.id=InstallingRhapsody&thread.id=26724
Feb 05, 2009 | SanDisk Sansa Clip MP3 Player
Installing the downloads in xp home edition
The only thing that comes to mind is you have some antiviirus/firewall software that will not allow it to load.
Depending on what type is is it can be blocking it without telling you or allowing you to pass the program.
This is a common issue with this type of software.
you can disable it but how depends on what it is.
if you can disable it then run the update manually.
start/windows update
Jan 29, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
