I bought this camera 5 hours ago and haven't done anything with it yet untill now. I take 1 picture en I want to test how detailed it is when I zoom in. After I do this, the lens can't focus anymore when I zoom out. Now if I try to shut it down, the screen turns black but the lens doesn't move at all! And after that I can't start it anymore for anouther 5 minutes. It can't be sand or anything because it's brand new.
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
If the pictures were on a memory card and you haven't done anything with the card since then, you may be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card into a card reader attached to your computer and run the program.
If you haven't done anything to the card since then, you may be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card into a card reader connected to your camera and run the program.
1st - how long ago did it get wet? 2nd - have you stored it in a bag of uncooked rice for at least 24 hours? (You can wrap it in a tissue to keep dust out of the dock)
If you haven't done the second above - regardless of how long ago it got wet - you should try this BEFORE trying anything else using electric current!! You may do more damage if there's water inside the case.
If the pictures were on a memory card and you haven't done anything with the card since you deleted them, then you might be able to recover at least some of them. Do a Google search for "data recovery software." Select a program appropriate for your computer and operating system. Put the card into a card reader and run the program.
Formatting the card wipes it clean and prepares it for use. If you haven't done anything with the card since then, there's a possibility of recovering at least some of the pictures. Do a Google search for "format recovery software" and select a program appropriate for your computer.
If the pictures are on a memory card AND you haven't done anything with the card since formatting it, there's a possibility of recovering some pictures. Do a google search for "format recovery software" and pick a program appropriate for your computer and operating system. Install the program, put the card into a card reader, and try it.
