Question about Lands Phones
My phone keeps on switching to offline mode and isn't recognising the sim sometimes (please note this is after a dropped my phone on the floor). Model is Nokia N73. Switching my phone on and off sometimes prompts if i wish to continue working in offline mode - to which i reply no and phone works fine again. Is there a way i can access the offline/online mode from the menus?
It would appear that the problem lie with the SIM card - my phone could no longer read the SIM and therefore only the offline mode was available. I tried my SIM in a different phone and it couldn't be read either. I replaced my SIM with a pay-as-you-go SIM and the phone was working perfectly well again.
I will be speaking to O2 to identify the problem with my SIM.
Posted on Sep 15, 2008
Nokia 701
you have to take it to your cell provider. It over heated the circuit board in the phone.
Apr 16, 2014 | Nokia N Cell Phones
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
How to make the nokia c5 phone from offline to online
My dear,
Just select settings, profile select the offline mode and it will be activated.
Or, you can switch off the phone, remove the sim card and switch on, it will ask "use phone in offline mode" click yes and phone eill be on in offline mode. When you insert sim card it will still ask the same question select any of your mind and enjoy your phone
Jun 08, 2011 | Nokia C5 Cell Phone
How to remove offline mode in nokia e72 mobile
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Feb 26, 2011 | Nokia E72 Smartphone
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
Dear sir imy phone is locked. i dont have password pl help me
try to do these.. 1.. switch off your phone 2.  remove battery 3.  remove sim and memory card 4.  reinsert battery and switch on 5.  it will go to offline mode.  6.  from offline mode, back up your files. ex.. contacts, tasks and notes.etc.. 7.. after back up, type this code to your keypad *2767*3855# it will bring your phone back to its factory settings but please be aware that you will lose all your settings on doing this.
regards..
Mar 10, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
My N95 Nokia phone in offline mode, I cannot call. SIM card not valid
try to check your phone profile settings,it maybe set to offline mode, if it is set to offline, select a different phone profile mode from the list of the options.
try also cleaning the contacts of your sim card card and try again. sometimes, dirt or dust can be a reason for your sim not to be recognized by your phone.
if you have done these steps, try your sim in a different phone and check if it can be recognized. try another sim to your phone if the sim can be recognized by your phone. in this way, you will have the idea of which of the two has a failure.
Feb 23, 2010 | Nokia N95 Cellular Phone
NO SIM MODE
try these steps..
1. get another sim card insert it to your phone (this will help you troubleshoot the problem between phone and sim).
2. check the phone profile settings, if it's on offline mode, then select general, or silent , it's up to you but don't choose offline mode.
3. clean the contact surface of the sim card by pencil eraser and a piece of clean soft cloth.
4. reinsert and try.
Feb 17, 2010 | Samsung Star GT-S5233 Cell Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Apr 12, 2008 | Nokia 3250 Cellular Phone
Lands Phones Logo
102 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
