Question about JVC GR-DX78 DV Digital Camcorder
Camcorder keeping going into Safeguard mode
I purchased a JVC GR - DX78 12 months ago. However recently i have been having problems with trying to use it. Each time i put the Camcorder on, it keeps going into safe guard mode. I get the message: " E02 - UNIT IN SAFE GUARD MODE - REMOVE AND REATTACH BATTERY" Each time i remove and then reattach the battery, it still comes up with the same message. Also just a few weeks ago, i am also having problems in getting the tape out of the camcorder. It is not ejecting. Each time it tries, its make a noise and then stops. Can you please help.
  • Anonymous Dec 29, 2007
    Please remove lens cap message even when cap is off
  • JVC Master
  • 5,577 Answers
5 Suggested Answers
  • 1894 Answers
SOURCE: How do I clear SafeGuard error mode off camcorder? eeror o6
hello
Posted on Feb 15, 2008
kala
  • 156 Answers
SOURCE: jvc GR-D250
There is any error code showing on the lcd screen?
Posted on Feb 28, 2008
  • 4 Answers
SOURCE: Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Posted on Dec 17, 2009
  • 44 Answers
SOURCE: JVC GR-D33U Mini DV Digital Camcorder Opened
check with
bestbatt.com about the battery. Thay have been very helpful to me and my JVC Minidv
Posted on Mar 15, 2010
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Sep 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
My camcorder goes into safeguard mode EO3 when I try to clean it.
I have had the same problem with a different model JVC. I haven't been able to fix it yet, but there were a bunch of people on a different forum that were able to fix that error code quite simply. With a tape in the machine, flip the lever to eject the tape, then as soon as you hear the motor start to whir, quickly close the door.
It didn't help me, but like I said, several people reported that that action fixed the EO3 error.
Feb 01, 2009 | JVC GR-DVL505 Mini DV Digital Camcorder
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
Apr 23, 2008 | JVC GR-SXM58 Camcorder
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Dec 03, 2007 | Video Cameras
JVC GR-DX78 DV Digital Camcorder Logo
59 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
