Question about Video Game Consoles & Games
My x box 360 wont go on x box live, apparently i have to add the consoles mac adress to my comp and disable mac filtering option
  • damehippy Sep 14, 2008
    still having trouble connecting to x box live, swithched off firewall as suggested, x box support tell me i have to add mac adress of my console to the allow list on my router, and disable mac filtering but i dont understand how to do this :(
    Scholar:
  • 94 Answers
You may need to open up some ports on your router cause most routers don't have an option to turn the firewall off especially NAT firewall and besides you don't want to turn that off otherwise some talented people could hack in to your network.
anyways here's link that would tell step by step procedure in forwarding a port on your router.
http://live.tommccann.net/
hope this will solve your problem...
Posted on Sep 14, 2008
    President:
  • 2,961 Answers
The easiest way of allowing xbox live, is to look in your router settings and look for uPnP, enable this and the router automatically sets up the xbox through the firewall, otherwise look for firewall ports and allow UDP port 88 TCP port 3074,UDP port 3074
  • 19,396 Answers
You need to disable all firewall.
If your router is set up with Mac filtering, then yes, you will also need to add mac address of your Xbox to the router settings.
If Mac filtering is not set up on the router, try just going into router firewall internal settings, and add Xbox IP as trusted IP.
Note: to access router settings you need to type in the router IP number into Internet Explorer bar, follow instructions on router manual to program the router.
    Genius:
  • 1,665 Answers
Make sure first you have correct connected.
Hi, i cant connect to my wireless internet connection on my xbox 360 super slim, i have xbox live gold though, how can i connect? it gives the same warning over and over again. I'm sure i have the right...
Depending on your router, it may or may not have a MAC Filter, which will prevent you from connecting your Xbox to the internet even though the Network Password is correct. If you have access to your router, add your Xbox MAC ID to your router's MAC Filter and then restart your router.
Oct 02, 2013 | Microsoft Xbox 360 Console
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
How do i add the mac address of my xbox 360 to my router
You have to go into the Xbox 360 network settings and locate the MAC address. It's either called MAC address or physical address. Then in your router, you have to find something called mac address filtering and add it to the list. If you don't have mac address filtering enabled, I don't see a reason why you would need to add it to your router.
192.168.1.1 Put that in your browser to access your router, the username is usually admin, and password is usually admin. Good luck!
Dec 16, 2009 | Microsoft Xbox 360 Console
Similar problem restated: Xbox live won't work
why would you eneter the same mac adress as your pc?
Apr 08, 2009 | Microsoft Xbox 360 Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
I cant get an IP adress what i it it says faild
If the X-Box is trying to connect wirelessly to your network, you might need to access the router page and check the wireless settings and make sure that you have the correct encryption or network key, Check the MAC address filtering of the router and make sure that it is disabled or it is off, If you are using a D-link router it is under the Advance tab, Network filter, on the other routers mostly they are under security options, Now after checking those on your router follow the following steps
- Go to the X-Box Dashboard
- Go to Network settings
- If the X-Box is wireless you should have on option for wireless at the bottom of the page
- Select your wireless network and test the X-Box Live
- If it is a wired connections
- Test X-Box Live It should now all connect and confirm the IP, DNS, ICMP
- NAT may show as strict but it should be able to connect to X-Box Live
- If you want to Set the NAT to Open
- Check the IP address of the X-Box by going to Network settings then Edit settings
- Then go to the computer again
- Access the router page
- Go to port forwarding normally located under an advance tab
- Open the ports UDP 88, UDP 3074, and TCP 3074 (here's one example, http://www.portforward.com/english/routers/port_forwarding/Dlink/DIR-655/Xbox_Live_360.htm)
- The IP address field must be filled with the IP address you got from the X-Box
Hopefully this solve's your problem sir
brakke_usaf..Good Luck and Merry Christmas to you and your family..
Dec 25, 2008 | Microsoft Xbox 360 Elite Console
Ip adress all messed up
is the ip adress set on DHCP?
if not, set it on that
Dec 08, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
50 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
